Question about Garden
Snapper LE 19 has not been used since last winter
Have added gas and oil mixed. Just need to know the steps I need to take to start it.
My husband is not here to help so I need help fast. Have 10 inches of snow on my driveway!
  • 420 Answers
SOURCE: Engine not getting gas.
If the fuel is getting past the fuel filter the issue could be a stuck needle valve in the carburetor. If the carburetor has a drain button on the bottom of the float bowl push it to ensure fuel flows freely for several seconds, if there is no drain plug or button pinch shut and disconnect the fuel line from the inlet to the carburetor, direct the line into a clean container and remove the pinch clamp, if fuel flows freely the filter is not clogged, if the fuel does not flow well replace the fuel filter.
To unstick a needle valve use a short blast of low pressure air (5-7 psi) into the carburetor fuel inlet, if the needle valve is stuck the air will tend to all blow back, once the valve opens you will here a change in tone. If you do not have access to adjustable compressed air try tapping the side of the carburetor gently, if it remains stuck you will have to remove the float bowl to gain access to the float and needle valve.
Posted on May 26, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a 20-30 year old EZ-GO golf cart and need
If you use a good, high quality 2 cycle oil such as Stihl, Echo, Husqvarna, etc. you can use a 40 to 1 mix in it.
Do not use a cheap "store" brand or some no-name product. The few pennies saved just isn't worth the price of a new engine.
Posted on Oct 30, 2009
Testimonial: "Thanks for the info. It was just what I needed."
  • 394 Answers
SOURCE: I have a techumseh snow
STIHL makes a really good oil for the 50:1 ratio. A STIHL chainsaw place sells the oil in little bottles. I bottle for one gallon of gas. Just mix the one gallon of gas with the one bottle of oil, shake it up a bit and pour the mixture in the engines gas tank. I bought a one gallon plastic gas container and put some spray paint on the out side ot it so I would always know the painted container would be mixed gas. Not to use the mixed gas in a different engine.
Posted on Feb 10, 2010
  • 4 Answers
SOURCE: Do I need to mix oil with my gas for the lt 1000
Simple, it is seperate. There is no need for a mixture
Posted on Jul 29, 2010
roadtech7
  • 297 Answers
SOURCE: I have a Troy bilt
You need to remove the carburetor float bowl and clean it. The needle and seat also need to be cleaned. The best thing is to totaly remove the carb. and soak it in a commercial/professional strength cleaner.
Your problem is fuel related, but just to make sure, remove the spark plug and spray some carburetor cleaner in the hole, replace the plug and give it a pull. If it fires up then quits..... The fuel system is to blame.
Hope this helps, Matt
Posted on Dec 10, 2010
22' snapper walk behind mowewont start .cleaned spark plug and still wont start .swapped spark plugs from another mower that does work and the other mower starts with the snapper mower's spark plug .
You need several things for a running internal combustion engine:
  • Air
  • Spark (to start)
  • Fuel
  • Compression
  • Lubrication
  • Exhaust.
You've shown that you have a workable spark plug so far. Going from the above, consider as well
  • Fuel. Bad / old / contaminated fuel. Clogged fuel filter. If it's a motor that needs gas/oil mix, does your gas have the right oil mix?
  • Air: Dirty, clogged air filter or air inlet.
  • Spark. Is any electricity making it to that proven-workable spark plug?
  • Compression. For this one, the most likely problem (other than a toss-the-engine thing like a broken piston) would be if the spark plug is not tightened into the mount hole, allowing the air to leak out rather than compress.
  • Exhaust. Most lawn mowers will have a spark arrestor on the exhaust to make sure you don't set a dry yard on fire with your exhaust. It's often overlooked in diagnosing two-stroke engines. Make sure it's not clogged or blocked.
  • Lubrication. Is there oil of the right type, and up to a proper level on the dipstick. No oil equals way too much friction in the engine.
Good Luck!
DH
Apr 25, 2016 | Snapper Garden
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the fuel mix required?
Pirelli an amazing walk on Christ The Redeemer
HB 180v home light mix at 32 to1
read it on the oil can, bottle, put 1 gal gas in first a marked clean gas can, and ad oil last watch the gas pump not the can, and stop at what amount of gas you need get 100 percent gas in all your trimmers ,blowers! // if the can you are going to use only has a small amount pour it out it might have water in it and that's another story. Rideau Canal Oil Gas Fuel Mix Tables and watch this neat video Christ The Redeemer!
Aug 21, 2014 | Garden
What 2-stroke mix for a Snapper mower (Briggs & Stratton 6.5 HP)?
USE A 32:1 MIX. THE MORE THE RATIO OIL TO GAS MIX RATIO THE MORE COOLER AND LONGER LASTING THE ENGINE WILL BE. 40:1 IS FOR FULL OUT TROTTLE CHAIN SAWS ECT.
Mar 13, 2012 | Snapper Garden
We have lost the information to make the gas mix for the trimmer. We used the gas mix we had last year and it put out a white exhaust. What is the gas/oil mix?
Hello. First, never use old gas ion a small engine. Use 1gallon of new gas and add one small bottle of mixinng oil, 2 ounces,available at any Walmart or auto parts store.
May 26, 2011 | Garden
I have a Snapper Yard Cruiser with a Kohler 15 hp OHV engine. Family no.SKH426U1G2RB; model cv15s; spec.no.41570. I bought this mower new and started having fuel troubles after about a year. My dealer...
I HAVE THE SAME PROBLEM. As soon as you shut the mower off, lift up the seat and turn the gas shut off to the closed position. Do this even if you are only going to be off the mower a few minutes. When you need the mower started again, open the gas shut off and start the mower.
Sep 12, 2010 | Omega Rear Drive Wheel Snapper Mowers
How would I know if something was put in the gas or oil tank is there a test to do on the bike to let you know. I got the bike from my X husband from divorce and he was mad so I know it tried to mess up...
Extract a good sample +- 200 ML of gasoline into a glass (See through). Let it stand for 10 minutes or so. Oil is denser than Gas. It should be on the top if there is oil added to gas. Similarly sand particles will form on the botom of the glass and gas and water should not mix either. It would help if i knew what you suspected but that is basically the way to go about. DO NOT START THE MOTOR untill you are sure there is nothing in the gas.
Jun 09, 2010 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
My redmax eb7001 emits white smoke while running, the more power...the more smoke
Your fuel-oil mixture has too much oil in it. The standard ratio is 40:1 which means one of the little bottles of 2-stroke oil (about 2.6 fluid ounces) is added to 1 gallon of gas. Homelite recommends a 50:1 ratio but 40:1 is better, at least in my opinion.
The last time you made the mix, did you pour the oil into the gas or did you pour the oil into a little bit of gas in the gas can, shake well and then fill it with a gallon of gas? The former can give you lots of smoke as well because it is not mixed thoroughly. The latter is the best way to mix because the agitation and the flow of gas mixes the oil better.
Other possible causes to this problem are: how old is the mix you are using? Did this mix sit all winter last and you sre using it now? If so, did you add some Stabil to the mix before storing?
Depending on your answers to the above questions, you can determine why you are getting so much white smoke.
My recommendation to you is to:
(a) Empty the blower gas tank.
(b) Mix a fresh batch of oil and gas in an approved fuel container.
(c) Pull the spark plug and inspect it, if it is black/sooty replace it.
(d) Pour the new mix into the tank and start the blower.
This should get rid of the excess smoke, if it doesn't, let me know here. Good Luck!
Oct 22, 2009 | Homelite 'Yard Broom' Leaf Blower
I guess he needs to know what kind of oil he needs also
you shouldn't need to mix oil with gas on a four cycle engine. this is for two strokes.
Aug 23, 2009 | Garden
Garden Logo
204 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
