Question about Toshiba A55-1063 Notebook
Toshiba sm30-106 not powering up
My laptop is not powering up, a blue light flashes when you insert the power lead which shows that current is flowing but thats all nothing else happens, please help.
My toshiba satilite L305D-S5940 Wont charge has new battery new power cord It comes on acts like its going to work then shuts off and sometimes wont come on What could it be please
1st : you can check from the power cable charge
2nd : check the adaptor charger if there is a light indicator or not, or you can check with multimeter to check the voltage on charger adaptor, does show the proper voltage for your laptop, you can check at the end of the connection that leads to the laptop.
note : Remember use DC current at Multimeter
3rd : if the adaptor running well, just plug on the adaptor charger to the laptop, dont turn on the laptop power, just see the light indicator with battery / lightning image on laptop, its explained that there is or is not the power current running to the laptop.
3rd.A : if its no power goes to the laptop then your adaptor charger is failed
3rd.B : if is there, there must be a problem with your motherboard, section power / power plugs, why do not want to charge with a new battery.
Conclusion :
- if the problem on number 1 & 2, then you can change the power cord and the adaptor charger.
- if there is problem on the 3rd.B then you can go to the toshiba services center for your problem.
thats all, hope its help.
Dec 01, 2015 | Toshiba Computers & Internet
Toshiba satellite c55-b5201 won't shut down its stuck on shutting down but still hasn't and the battery light is flashing help i don't know what to do
Best to pres the power button for a few minutes to force shut down and restart.
If that doesn't work then remove power lead and pull the battery out and re-insert battery and power lead and restart.
Sep 16, 2014 | Computers & Internet
Is there any way to get past the EC power restriction foir BIOS FLASH...My L675D-S7049 Toahiba Laptop had a DEAD (Totally) battery due to a friend...AC shows input but NO CHARGING with new battery (OEM)...
The bios will and does not affect battery charging. Battery charging is carried out before the system and is a switch mode charger on board before the processing. If it required the processor to work and a bios, it would not charge when switched off!
I would suspect the OEM battery for the flashing light but the laptop should switch on with just mains power.
Has it been overheated?
May 29, 2012 | Toshiba Satellite Black 173 L675DS7049...
My toshiba a200 does not work on charged battery ,but when plugged in it sometimes works and sometimes cuts and dies and shows flashing blue light and refuses to boot at this stag.e,can you help...
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Nov 13, 2010 | Toshiba Satellite A200-0ET00X Notebook
No power from laptop just a flashing blue light,
THE SYSTEM SHOULD BE CONNECTED TO POWER SUPPLY AND REMOVE THE BATTERY AND TRY TO ON THE SYSTEM .IF IT BOOT THEN AFTER THAT INSERT THE BATTERY SO THAT IT CAN CHARGE VERY WELL OR CHANGE THE BATTERY....OK RATE THIS SOLUTION
Apr 30, 2010 | Toshiba Satellite A200-0ET00X Notebook
Toshiba a200 flashing power light .. blue blue red red HELPPPPPPP
Remove battery and power
Remove memory in lower socket, the one on the system board and try reboot with just power cord. May have bad socket
Dec 11, 2009 | Toshiba Satellite A200-0ET00X Notebook
DC in light flashes orange
You need to test the AC Adapter For Correct Power Flow-Through... Use A Multimeter (available at any Home Improvement Store)
If That Tests Good.....
You Will Need To Test The DC Jack (the port where your Charger Cord Plugs Into On The Laptop.....)
If An Incorrect Adapter Was Used, You Might Have Shorted Out The Motherboard..
Dec 01, 2009 | Toshiba Computers & Internet
Toshiba Satellite no power
replace only the power jack and clean the power supply board with some alcohol...you can find the jack in some electronic shop..
Jan 04, 2009 | Toshiba Satellite M45-S169 Notebook
Toshiba Equium A200-1VO won't turn on
Remove the power adapter and the battery. Hold the power button in for up to 60 seconds to discharge the laptop. Try starting it again.
Apr 22, 2008 | Toshiba Satellite A60 Notebook
Toshiba A55-1063 Notebook Logo
182 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
