Question about HP LaserJet 4000n Printer
HP Laserjet 4000N (networked printer) suddenly will not print jobs. Will hold in queue and must go to printer to get it to continue. We have many computers (mostly Macs in varying OS versions - 9.2.2 to 10.5 - but a couple of Windows XP machines) utilizing this on the network. It is set for auto updates so I think these are all current. This just started to happen after working fine for many years. Any suggestions on what to do? Thanks.
  • Dustin Reid May 11, 2010
    Can you clarify a few things for me?
    1. Firmware version
    2. Jet Direct Card version
    3. Any error messages?
    4. How do you get it to print from the printer, what steps do you follow to release the documents from the queue?
    Thanks, with that info I can help you solve this. Or at least point you in the right path.
  • 2,120 Answers
Replace the 615n network card.
Posted on Jan 29, 2009
49.4 C18 laserjet 4345
49.XXXX is a fatal catch-all error. Could be firmware problem, network, print job. If the error occurs when you try to print, clear the print queue. If the error occurs when the printer is just sitting idle, reseat the formatter. Try powering on without the network cable attached. If it still happens replace the formatter. Could be a corrupt print job being sent to printer. Print something else.
Mar 28, 2014 | HP LaserJet 4345mfp Printer
One of the hp 9050n printer have 49.2f83 eror what is the solution please
Follow these steps.
1. disconnect all parallel, network and usb cables and power cycle printer. If it comes to ready good.
2. After making sure that all print jobs are cleared from printer queues, reconnect the network cable or parallel cable. If printer stays are ready, good. If it errors again, likely a stale print job that you missed in a queue. Check and start over.
3. When you can get the printer to ready with the network cable attached. Go to and download and install the latest firmware on the printer.
If the printer continues to 49 you can try updating the print driver as well. If the 49 error is persistent, remove the formatter and try to perform an engine test. if the engine test works then you have either a bad formatter or bad memory on the formatter. Remove memory and restart, still error, then formatter it is.If the engine test does not work then you may have a bad dc controller.
Mar 08, 2014 | HP LaserJet 9050 Printer
I have a HP 4000n printer and want it to print from tray 3 when tray 2 is empty. It doesn't do that now.
I don't have a 4000n, but I do have a 4200n that should be relatively similar. On the 4200n you can change this behavior by going to the menu, then Configure Device->System Setup->Tray Behavior->Use Requested Tray, then setting that value to First. My guess is you have that setting on your 4000n set to Exclusively, which will then prevent the job from going to a different tray. It also requires that you have the same type and size of paper registered in both trays if you want the job to automatically switch over.
If that menu path is different on your 4000n you just need to dig around in that menu to find the tray behavior setting.
Jun 09, 2011 | HP LaserJet 4000n Printer
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
Printer has always worked great, gets lots of office usage, but now suddenly won't feed; the machine will turn on, when the print queue is activated, but just "clicks", won't feed and the error...
Try The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 27, 2010 | HP LaserJet 1020 Printer
Does it show "Printing" or "Spooling" in the job queue window?
Open the Job queue window, then highlight and cancel the print job. Send a small print job to the printer and make sure that the PC and the printer are communicating.
If the failure re-occurs, then clear the queue again and close it and restart i=the queue.
Dec 14, 2009 | HP Hewlett Packard LaserJet P1005 Printer
HP P2015dn setup in a language lab, serving multiple computers via a network. If the printer is off for most of the day, when it is turned on, the backup of jobs starts to print. How can I clear the queue...
If you have switched off the printer all jobs in the printermemory are gone. If the printer starts printing jobs when you switch it back on, there are still some printjobs in the system or on one of the pc's.
Gerrit Jan
Nov 10, 2009 | HP LaserJet P2015dn Printer
Print jobs stuck in queue
First re-install the printer driver on that computer. If you can see the jobs in the queue, cancel all jobs and try again. Hope this helps.
Apr 20, 2009 | HP Color LaserJet 2600n Printer
Hp laserjet p1006 printing jobs gets struck in printing queue
I know this problems in my part it was the hp driver.
My Solution is to use an compatible driver.
HP Laserjet 5 / or 6 standard windows driver.
After that i have not this problems.
The secound problem is that this printer have very less memory and big pages in a few times are not able to print.
Dec 25, 2008 | HP LASERJET P1006 Printer
Printing problem
The printer itself is printing, but when I stalled Laserjet 4000 and try to print it shows ERROR even printing test page. I do not know why my HP laptop Vista cann't recognize the printer!
Nov 23, 2008 | HP LaserJet 4000n Printer
HP LaserJet 4000n Printer Logo
89 people viewed this question
Ben Johnson
