Error 323 I purchased a dir-320 router when I try to set up the connection it is telling me that the router setup requires your new router to be configured with the default username and password. It is also telling me that i need to restore my router's factory defaults. I don't know how to have it done. Can someone please help.
  • Anonymous Feb 23, 2009
    I have the same problem
    as maggie
To restore factory defaults, press the reset button located at the back of the router for about 10 secs.
Posted on Jan 29, 2009
I purchased a D-Link Wireless N 150 Router, Dir 600L. I am unable to setup the same. Do I need a Modem also to setup this router or I can setup without a modem?
You can setup a wireless network without a modem. It will allow you to share printers, files ect. The modem is required for an internet connection only. The modem basically translates the Ethernet traffic in to a signal that can be carried over your respective service, DSL over a POTS line or broadband over a coax cable. The word modem stands for MOdularDEModular note the word MODEM in there.
Dec 24, 2012 | D-Link DIR-600 Router
I get an error 323 during setup
Are you trying to run the CD to setup your router?
I will suggest you to install your router manually.
It is very easy.
Connect one computer to the router. Open the setup page of the router and change the settings manually.
See Linksys router setup.
Jan 09, 2012 | Linksys WRT54G2 Wireless Router
How do i connect my DIR-142 to my ps3.
try to use port forwarding, Just go to your routers webpage, then advance and look PORT FORWADING option, set the port for your PS3 then assign an IP on it then save and exit. Hope it helps thanks.
Sep 22, 2011 | D-Link DIR-412 Mobile Broadband Wireless...
Error Information: Router Setup requires your new router to be configured with the default username and password.
Are ytou trying to setup the router.
reset the router to the factory default settings. On the router You will find a small reset button.
Press it and hold it down for 10 to 15 seconds. Release the reset button.
Wait for 1 minute.
Now unplug the power cable to the router and plug it back in.
Wait for 1 minute.
now try to run the setup disk.
If that doesn't work then you can also setup the router without the CD.
Click Here for more information about the routers and network
Jul 04, 2010 | D-Link DIR-600 Router
Error 323 Could not access new router
Hi, try resetting the router settings to default using the RESET button at the back. Configure afresh.
Feb 22, 2010 | Computers & Internet
Please help.... I have just purchased a dlink dir-600 wireless router and I can not connect to 192.168.0.1 from my mac.
For setup, you need an Ethernet cable connection to the router, WLAN needs to be configured first before you can use it to administrate the router.
Quick installation guide is here: ftp://ftp.dlink.de/dir/dir-600/documentation/DIR-600_revb_qig_multi.pdf
The default user name is "admin" with empty password.
If you suspect the settings are not at factory defaults, press the reset button at the rear for 20 seconds with the router powered on.
Feb 09, 2010 | D-Link DI 514 Wireless Router (DI-514)
Lost my d-link dir-655 quick router setup wizard CD, can i get one?
Are you trying to set up the router?
you don't require the CD.
You can change the settings of the router manually also.
Click Here for more info about the router set up
Oct 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Hi I cant configure my router D-link DIR-300
Hi! I will be more than glad to assist u in this concern..Please dont use the setup cd or setup wizard. you can access the setup page of the router by typing at the url:192.168.0.1 then it will ask for the user name and password, by default the username is admin and the password, leave it blank.. here are the things u need to check before u setup u router.. .. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Jul 29, 2009 | D-Link DIR-300 Wireless Router
New dir 625 with DSL-cat5 connection and NO internet on status.
If it keeps on trying to connect to PPPoE, try not to use PPPoE setting. Use Automatic Configuration or DHCP connection type.
Jun 10, 2009 | D-Link DIR-625 (790069292637) Wireless...
Computers & Internet Logo
648 people viewed this question
David Payne
David Payne
