Question about RIM BlackBerry Pearl 8100
Rollerball of my blackberry8100 is nt working
Rollerball of my blackberry8100 is not working.It does not scroll downwards.We have no blackberry service center in Lucknow.Please help me,Give me some solution as soon as u can.
Use Rubbing Alchohol on a Q-tip to clean the roller. This happens to me all of the time and this always solves the problem
Posted on Feb 03, 2009
Rollerball downward movement does NOT register. Upward OK. Click OK.But cannot scroll downwards
Same problem I had. Remove the ring around the track ball assembly. and remove the track ball assembly frrom the phone. Clean the ball well with a swap and alcohol. Make sure you put the assembly back in the same way it came out. Put the ring back on and you should be good to go.
Nov 24, 2009 | RIM BlackBerry Curve 8310 Smartphone
Rollerball not working
On the BB 8800.......you need to have the board service....this will solve the problem on your 8800 Blackberry.
the roll ball......on the pearl....you need to have the pad on the board replaced so take it to a professional mobile technician and have that done.
Jan 03, 2008 | RIM BlackBerry 8800
My Rollerball won't scroll down - tried everything.
Cause: The sensitivity of the trackball/trackwheel might be less Faulty Hardware Resolution: Increase the sensitivity by following procedure Option -> Screen and Keyboard -> Horizontal Sensitivity and Vertical Sensitivity to 100 If not working check with the service center
Aug 11, 2009 | RIM BlackBerry Pearl 8100
Rollerball assembly help
this link tells you how to put it back in the correct way...
http://jsdoodnauth.wordpress.com/2008/09/23/blackberry-pearl-trackball-stopped-working/
very good explanation includes pictures
May 04, 2009 | RIM BlackBerry Pearl 8100
had same problem. used rubbing alcohol with a cotton swabb. Took a couple of applications, but worked brilliantly within 10 minutes. Thanks!
Mar 06, 2009 | RIM BlackBerry Pearl 8100
Blackberry pearl turns off when i touch the rollerball
Try a different ball in the device they are fairly easy to remove. Borrow a friends entire track ball use nail file to remove the ring then look to make sure what way the mechanism and ring go back in and try your firends if his/hers works in your phone replace the defective part. 2b4daea.jpg fb71594.jpgeb3c8be.jpg
Dec 29, 2008 | RIM BlackBerry Pearl 8100
Blackberry Curve rollerball scrolls but will not select when push
Try removing the silver cover around the scroll ball, and remove the ball. There should be a little white square underneath it. If there is no white square, but a red square, then it could be water damage. I had the same issue with mine.
Dec 15, 2008 | RIM BlackBerry Pearl 8100
Rollerball Issues
Try cleaning the trackball. Use a q-tip dipped in IPA or rubbing alcohol and use it to rotate the ball around a few times. Try a few times to make sure it is clean.
Aug 25, 2008 | RIM BlackBerry Pearl 8100
Blackberry rollerball
Hi guys I have the solution. I think all your trackballs are stuck. If you cant move it, take the silver ring off with a knife, take off the trackball and put rubbing alcohol on it wth a Q - tip until it works. Can some1 help me? My problem is titled My blackberry pearl wont load up.
May 16, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
163 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
