Question about Toshiba Satellite M35X-S349 Notebook
Lap top power supply
Hi dis is abhinav i had some problem with my laptop in power supply when i used to charge it the screen is brigtning nd i remove da power also it is showing the brightness as it shown when charging please give me solution for da problem why it creating so thanking u.
  • Dan rogers
    Dan rogers May 11, 2010
    When the laptop is plugged into the power supply the computer shuts off power saving mode. Thus the screen gets darker. To change this just go into the power settings in the control panel.
    Start menu>control panel>power options
M y Mini Hp lap-top is on and can not switched off
dis-connect the power supply adapter and the main battery, press and hold power for 60 seconds to reset the processor, now hook everything back up and power on.
Aug 16, 2012 | HP Mini 1000 Netbook
Hi, the charging connector is broken, can it be replaced easily? If so , how do i get to it? the lap top is a TJ74-RB-050UK. Cheers
the dc jack (charging connector) can usually be bought for about 5 pounds or less from ebay. As far as fitting it goes it depends how confident you are. You will need to disassembel your laptop and remove the broken jack from the motherboard and then solder the new one on.
Jul 15, 2012 | Packard Bell (190169) Power Supply
Lap top will not turn on. receives power from the cord and power supply, but has no indicating lights on the lower left part of laptop. was able to get the lap top to operate after removing and...
Measure the voltage at the terminals of the battery in the laptop. If there is no supply then the power section in the lap tops main board is faulty and needs a check.
However if there is voltage then the battery must be checked if this has failed to charge and is defective. check if the cord from the adapter is not short as it will result in DC power cut off.
Mar 24, 2011 | HP Computers & Internet
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
I recently buy a laptop of dell vostro 1015........ nd vendor installed a windows 7 on my lapy... but after 2 or 3 days my system stops working like device manager is not responding,internet explorer not...
Hi
I strongly you lap got affected by some kind of virus. Better you can take the lap to service center and they will format the entire hard disk not a single partition . You can also try the same way
Thanks
Oct 27, 2010 | Dell Vostro 1015 Laptop
How do I charge my battery on my t30 lap top battery
You normally need a compatible Power Supply plugged into the Laptop from the mains. Without this the battery will go flat. If you do not have one a good place to look is Ebay, or the like simply put in the model name of your laptop and the words Power Supply.
EG: IBM ThinkPad T30 Power Supply.
Feb 03, 2010 | IBM 11P8273 for Thinkpad 14.1" Flat Panel...
Concerning the battery chargers for 5100 and 5315...I had the Amps backwards...5100 is 4.74A and the 5315 is 3.42A..so the question now is: can i use the 4.74A charger to charge the 5315 lap top (which is...
Hi there.
You must only use power supplies which are specific to that particular laptop, even if you have a power supply of the same voltage but the amps are different it may power the machine but in my experience they have blown the PB (power board) which has resulted in no charge at all right down to the motherboard itself being blown.
I suggest you use the power supply specific to that laptop.
Good luck and thanks for using Fixya!!!
Mar 02, 2009 | Acer Aspire 5100-3357 Notebook
Battery not getting charged
Hi there
This is a common problem with laptops, you will need to have the battery checked as it could be damaged and needs replacing. Alternatively it could be the motherboard or the power supply itself which is faulty
Jan 13, 2009 | Computers & Internet
Display problem
the best thing to do is to get the help of a qualified technician(better go to a toshiba service centre)
they will help you with this.
try removing the battery after turning off the computer and removing the power supply.reinsert the battery and turn on th notebook. it should work fine.
else contact the technician.
Dec 03, 2008 | Toshiba P25-S676 Notebook
Toshiba Satellite M35X-S349 Notebook Logo
110 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
