Question about Canon BubbleJet i560 InkJet Printer
Yellow ink contaminated
My yellow ink pad is constantly contaminated (for want of a better word) by the black ink so my colours don't print correctly. I can fix this temporarily by blotting the pad with a tissue and then running a clean and several nozzle checks but it wastes a lot of time and ink. Any suggestions please?
  • Flashtwo Jul 09, 2008
    I have the same problem with the Canon i950. The black cartridge seems to soak into the yellow one - capillary action? Very wasteful of ink. After cleaning with tissues I put in a new yellow. - it worked fine but the next day the black had contaminated it again. I have cleaned it again, put in another new yellow and now remove the black when I've finished printing. I hold the original orange plastic tab in place with an elastic band. I have only ever used genuine Canon ink cartridges.
    Sergeant:
  • 390 Answers
Yes, do you refil your own inks. Colour contamination occurs primarily when users overfill ink holes with any colour, then this colour runs into others and voila, a yukky mess. If cartridges are fairly new, heres the quick easy fix. Remove cartridges that are causing the problem, in your case all! Using a proper cleaning solution (you can get this free in refill kits or buy it sepeartely, i got mine from supermarket, works well) and cotton buds, thoroughly clean down where the cartridges sit. There will be both fresh ink and dried ink, so you will have to repeat over and over until all or most colour is gone from cotton buds. Now, let it dry and air, leaving printer cover open. You now have to bleed the black ink as it sounds like it is overfull. This can happen in refilled cartridges, but even store bought ones can have faults. Sit the black cartridge on wet paper towel, on a clean icecream lid or marg lid, even a plate will do, just one that you don't mind ink on by accident. Let it sit a minute or so, now lift it up, and wipe it gently with a wipe (i use unscented baby wipes-huggies, do not laugh, they work well!) press it firmly on a folded tissue, and it should leave a nice clean neat black vertical little line. If it doeas, place it back in its place in printer. Leave open for now. The colour cartridge should need cleaning too, by doing the same, each time you lift it off wet paper towel, wipe it clean, and press it on a tissue to see clean neat 3 colour line. If not, bleed again until it does. When it does place it back in printer and reset ink levels once cover is shut. Try printing now.
Posted on Aug 31, 2007
Colors not matching computer
It is possible your colour cartridge has cross contaminated the ink reservoirs. To check this take the colour cartridge out and turn it over to see the coloured pads. They should look red, dark blue, and orange ( the colours are actually Magenta, Cyan, and Yellow, but are concentrated). If any of the pads are pale or particularly green - change the cartridge.
If the colours look alright, your issue is probably that your monitor makes colour by emitting light frequencies so is bright, printed images make colour by absorbing light frequencies so will always be darker. There is always the issue of course that your monitor also has a colour "temperature" bias. Photo pros calibrate their monitors and printers to match.
Mar 25, 2012 | Canon PIXMA iP90v Printer
My Brother inkjet printer (DCP-585CW) is not printing yellow colour.
If the yellow ink is not printing here's what you can do:
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink Management button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink Management button on the control panel and select cleaning press ok
3. Press the up or down arrow key to select Color press ok and press Black Start.
*After the cleaning process the printer will ask you if the quality is OK, press up or down to select yes or no, and it will ask you whether black or color is ok, once you have selected you're answer press Black or Color START to print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps.
Rate if it worked Thanks!
Apr 03, 2011 | Brother DCP585cw AllInOne InkJet Printer
My yellow ink is printing black. I have swapped the ink cartridge, and tried running a few test prints, but the yellow is still black and affecting all my colour copies
The driver software for your printer may have been corrupted and should be reinstalled. By Switching the cartridges around you may have contaminated the ink jets which should either eventually self clean. If not you may need to have the unit professionally cleaned try buying a printer cleaner first and see if that works first that should do the trick!:) Hope this is helpful :) Please remember to vote Thanks
Jul 24, 2010 | Brother MFC 210C All-In-One InkJet Printer
Out of yellow ink but only want to print in B&W
please you use the coloue paper print other black and white paper print ?
but you use the only yellow paper print ?
you refling the colour cartridge and setting page in colour prints
and use printer.
Sep 27, 2009 | Brother MFC-260C All-In-One InkJet Printer
When printing colour, black appears green
A worn out printhead can allow inks to contaminate each other, after cleaning you need to check your cartridges, if yellow is a brown color, you are getting contamination and need to replace the printhead. Black is hard to tell but when cyan gets too dark it's contaminated as well.
Aug 12, 2009 | Canon BubbleJet i560 InkJet Printer
Printer is refusing to print colour, with full colour ink tank.
Have you checked the ink levels in your cartridges? Ink can dry due to usage and also due to prolonged non usage.
Apr 13, 2009 | HP LaserJet 1100 Printer
The ink cartons are full. Printing is not taking place
Hi I think I had a similar problem, I let the black and cyan run down really low. then it took a week to replace the cartridges. The result was no black and cyan. I put in new cartridges and of course no colour.
Solution: Take out the cartridge holder and take a cotton bud and soak all the ink pads in alcohol (no not beer)
I used clear alcolhol from the chemist, the reason for this is it dries out very well after the clean process with no contamination. Give the ink pads a good soak and rinse out in very hot but not boiling water and allow to dry. Then go through the deep clean process in 'printer maintenance'
You may have to do that several time but be patient and it should clear out and start to print again.
MCL
Mar 30, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Hp psc 1510 - only want black ink
Hi Manavoc,
I will explain you the cause for it.
It prints in yellow first and then override with black for better quality. This is the reason your color ink gets empty.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00308490&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Have a great day!
Mar 20, 2008 | HP PSC 1510 All-In-One InkJet Printer
Dissapearing yellow
I run about 100+ canon printers from s800 up to the new ip4500.
I have met and solved almost every problem I find described on the web. Your problem with the disappearing yellow ink can be only one thing. The ink cartridge has not been sealed after you injected the ink. If there is even the smallest avenue for air to get into the cartridge it will allow the ink to flow very rapidly back out of the cartridge and into the waste ink pads in the bottom of the printer. You won't be able to see a puddle of ink under the printer until much later when you have done many cleanings or installed many leaky cartridges.
Dec 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon BubbleJet i560 InkJet Printer Logo
293 people viewed this question
old marine
old marine
