Question about Garland H283 Gas Kitchen Range
What do I clean my 60" garland double oven with?
I purchased a home with a 60" garland double oven that needs a good cleaning. What do I use on the stove, oven and griddle?
    Novelist:
  • 125 Answers
Hello. Try going here:
http://www.garland-group.com/?xhtml=xhtml/gar/us/en/general/productdownloads_service.html&xsl=productdownloads.xsl
this manual may not apply to your unit specifically, however, it does contain cleaning information specified by the manufacture for oven,grill, exterior, and stainless surfaces.
Hope that helps, and thank you.
Posted on Feb 22, 2009
    President:
  • 2,559 Answers
Use warm, soapy water for everyday cleaning, and dry with a soft cloth. Use a mixture of 25 percent white vinegar in water to remove mineral deposits left by hard water. Step3Remove burned-on food, wash with warm soapy water and a scrub brush made of nylon. 4Remove rust with an oxalic acid cleaner such as Bar Keepers Friend 5 Use glass cleaner and a soft cloth to remove fingerprints. Polish stainless steel with a paste made of water and baking soda. Rinse and dry thoroughly. Please rate this fixya
Posted on Jan 28, 2009
Once we light the pilot light it keeps turning off how do we keep it on
makeed sure that the pilot flame is properly direct on the thermocouple if thats ok then replace the thermocouple
Jun 02, 2010 | Garland GPD-60-2 Gas Double Oven
Double oven, top oven run by keypad turns off
I have a double oven. The top unit works fine. The bottle unit will turn on to cook or clean. Then after a few seconds it turns itself off.
Oct 12, 2009 | GE Profile JKP56 Electric Double Oven
I have apyro deck double pizza oven can not find model number
someone drilled the orfices to clean them this was a used oven
Sep 18, 2009 | Garland Ovens
Garland oven MOD# MST43RE White flames and a lot of black.....
I adjusted the air mix, main burner was full of black stuff inside so took the air compresor and cleaned it good. Now i have nice blue flame!
Gasman77
Mar 25, 2009 | Garland M-2 Oven
Every couple of days the pilot light goes out.
Hello. It sounds like you are able to relight it, and all is good till the next time. I would suggest replacing the thermocouple for the oven, and cleaning the pilot. The pilot is probably dirty, they draw dust into them while burning, and thermocouples are reasonably priced. You could be having a problem with your pilot safety, the part with the red button that you push to relight the pilot, however it is easier, and cheaper to get a new t'couple,and clean the pilot first.
You can go to: www.garland-group.com or call them for parts 1.800.424.2411. There are many part suppliers online that can get what you need.
Feb 04, 2009 | Garland H286 Gas Kitchen Range
When Oven turns off so does oven pilot
Hi there, it is possible of the pilot being too close, but usually does not have that effect, unless the pilot is too small. But if you replaced the pilot, it should be clean, so next I would look at the gas pressure, if this is too low, the flame won't have proper burning speed, and strength, and could get drawn out. The control valve may be of the type that has a regulator built in, you may need someone skilled at gas pressure measuring, to do this, your gas supplier, appliance professional, plumber, should be able to do this.
Let us know, and thank you.
Jan 29, 2009 | Garland GPD-60-2 Gas Double Oven
Model GPD-60
Look for spring or the lock tear side of the door applied small tin sheet can hold door lock and drill and then revit it.
Dec 30, 2007 | Garland GPD-60-2 Gas Double Oven
Garland stove pilot light problem, again but different
I'm not familiar with Garlands. When I run into a similar problem with other stoves of that vintage (Wedgewoods, etc.) I trace the pilot lines piece by piece, from the manifold to the pilot burner, if necessary opening a connection or two to see where I'm getting gas and where I'm not.
Is there a needle valve for adjusting the pilot flame? Is there gas getting all the way to the pilot burner? When it's the pilot burner itself that's the problem, I take it apart, brush/blow/shake out the crud, and run a small drill (#79 or so) through the orifice.
Dec 19, 2007 | Garland H283 Gas Kitchen Range
Oven pilot light will not stay lit on Garland 6 burner, double stove, salamander commercial in home
Use a needle right where the pilot flame comes out. Should do the trick. GOODLUCK!!
Dec 16, 2007 | Garland H283 Gas Kitchen Range
60" double oven gas Garland stove
We use a Garland from the 1960's and pilot lights ARE scary and should make you nervous. This is why they are no longer allowed in new gas ranges. I mounted an inline gas shut off to the stove where the gas enters (on mine this is right in front on the left side). It turns on and off like a burner and when we are done cooking we simply shut off the gas there. To light the burners or the stove I use one of those long reach lighters. I go to bed knowing that NO gas is coming in.
We love the stove, it makes cooking more fun.
Good Luck!
Oct 24, 2007 | Garland H283 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
352 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
