Question about AEG Lavamat 74640 Front Load Washer
Aqua-lock inlet hose connection on dishwasher
Does the aqua-lock have to be installed vertically under the tap or can it be at any angle?
    Genius:
  • 2,920 Answers
Can be at any angle as long as you dont crimp the hoses
Posted on Jan 28, 2009
How do I get to make it stop and work .Dishwasher is not shutting down it says E 15 Water tap flashing , and red Aqua stop light .
inlet valve is the aqua stop long hose to tap has a solenoid at tap end that is likely your fault
Sep 29, 2016 | Bosch Dishwashers
AEG Favorit 44090i Dishwasher will not fill with water
There may be a filter after the aquastop pipe which is blocked. This is usually at the back of the inlet valve. Also, the inlet valve may no longer work.
Nov 07, 2014 | Dishwashers
AEG Favorit 44080i Dishwasher will not fill with water
Well, this was very long-winded. If it works when filled manually, then check the stopcock for the water flow and open it more if not all the way. If this does not work, try the water pump in the back/bottom of the disher
Can i remove the aqua solinoid cut off valve from bosch dishwasher
the valve and wiring can be replaced you cannot remove it altogether as it wont be able to fill up, bosch aqua stops are normally powered solenoids that also double as the water inlet valve unlike most other aqua stops
Sep 27, 2014 | Bosch Dishwashers
Aqua stop hose allows water through when disconnected from Whirlpool dishwasher but stops water when dishwasher demands water
looks to me like as if the direction of the hose is incorrect. Check to see if there is a direction of flow arrow on the hose and point that arrow away from the tap towards the machine.
Jan 15, 2014 | Whirlpool ADG175 Builtin Dishwasher
I have just bought a miele 5100 dishwasher, my husband connected it, but the inlet hose connection that goes to the water supply, which has a large plastic piece on it is leaking, you can click it open but...
the big box on the tap end is called the aqua stop fitting. If it leaks around the tread make sure there is a washer in the big nut that screwas onto the tap. The tap might be old and not true on the fase. You could try some thread seal tape on the tap thread. good luck
Feb 10, 2011 | Miele Dishwashers
Where is an Aqua-stop fitted in a dishwasher?
In the water inlet hose close to the valve on your supply end,its encased in a big ( 2") plastic housing with a brass fitting.
Hope this helps.
May 21, 2010 | Siemens 24 in. SE25A266 ExtraKlasse...
How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
Jul 09, 2008 | Bosch 24 in. SGS43C02 Classixx Built-in...
Dishwasher doesn't fill
try looking at the regultor it might be blocked theres a finn tube check it as it could be bunged up with muck
Mar 02, 2008 | Dishwashers
Neff Dishwasher
Hallo Champer, 1)Be sure water supply is arriving with enough pressure. 2)If the hose between the crane and dishwasher has an aqua-stop ( or water-stop) which you recognize at the hose being enlarged twice the size close to the crane, possibly water supply can be blocked there. You can change it temporarily with a regular hose ( for garden or car-wash ...). If dishwasher is doing the job buy a new hose with Aqua-stop in a regular electro- household appliances shop. 3) If this solution is not the good one, you might check in fact to the inlet valve, which you find at the other side of the metal plate where the watersupply is flooding inside the diswasher. Generally a white coloured threaded plastic pipe. Unplug your dishwasher, close water supply (!) and disconnect the water hose. Open the dishwasher ( either top-plate and/or back-panel). Now you see the inlet-valve ; unscrew this one and mark the position of the 2 electrical wires, which you also unplug then. Also unplug the internal water drain, and ask again a regular shop (see 2) if they can check this valve and if necessary get a spare part. Oeffti, hopefully this helps else let know.
Nov 01, 2006 | Neff 18 in. S5943 Slim-Line Built-in...
AEG Lavamat 74640 Front Load Washer Logo
971 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
