Question about Intel Motherboard
Not any detect sata new device
Sorry i can't?
  • 56 Answers
NEW MORE INFO
MAY NNED DRIVE PRO,
SOFTWARE THAT CAME WITH THE NEW HARD DRIVE.
GO BACK WHERE BOUGHT IT AND ASK QUESTION,
GO TO WEB SITE OF THE HD MANUFACTURE
GIVE ME THE MANIFACTURE NAME AND I GIVE YOU ADDRESS MYSELF.
IF I HAVE IT
CANDYMANGANDY
Posted on Jan 28, 2009
Acer Aspire X3300 not detecting on-board SATA controller
HINT:
1) Try to reflash the BIOS.
2) Look for new firmware Flash update /then reflash BIOS.
3) buy a new bios module equal to yours and seek help on tech to disoldering module to the new one.
Carl
Feb 24, 2016 | Acer New Aspire X1200 X1300 X1301 X1800...
I got a new SATA 500gb HDD but the motherboard wont detect it.
Access to your Bios Setup & configure the Bios settings.
Features Setup Page : This page sets up some parameters for peripheral devices connected to the system.
CMOS SETUP UTILITY - Copyright (C) 1985-2003, American Megatrends, Inc.
Features Setup
OnBoard Floppy Controller : Enabled
Serial Port1 Address 3F8/IRQ4 : Enabled
OnBoard IR Port : Disabled
Parallel Port Address : 378
Parrllel Port Mode : ECP
ECP Mode DMA Chnnel : DMA3
Parallel Port IRQ : IRQ7
OnBoard PCI IDE Controller : Both
OnBoard SATA-IDE
: Enabled *(Make sure This is enabled)
Audio Device : Enabled
Modem Device : Auto
Ethernet Device : Enabled
If you have got a SATA III HDD, ie if it is a Western Digital Sata III you need to configure the jumpers to work with your older Sata interface port.(Only Sata 1 & 2 ports on your Mainboard Socket 478). As for Seagate Sata III HDD, the configuration is automatic.
If your 500GD HDD is not detected, try updating the BIOS!
A word of caution "Updating the Bios is not for the Novice" Do it at your own risk. Failure in updating the Bios may render your Mainboard useless.
Hope it helps.
May 14, 2011 | PC Chips M955G Motherboard
Any sata hdd can't dected by the mother board but any sata dvd dected by the mother board. what kind of procedure i followed now?
Your motherboard CAN detect a SATA device.
Your motherboard DOES detect your SATA optical device.
Your motherboard does NOT detect your SATA disk-drive.
This suggests that your disk-drive is "dead".
Exercise the WARRANTY on it, to get it repaired/replaced.
Or, if the warranty has EXPIRED, purchase a new SATA disk-drive.
Feb 03, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Sir my problem is that my SATA hard disk not detected by system. Also when i detect the SATA/IDE hard disk system hang, and nothing happen. But that time keyboard not hang. My SATA ports work...
Each PATA device (disk-drive or CD/DVD) drive has some small jumpers.
For the two devices connected via the one ribbon-cable,
set the jumpers on one device to the MA(ster) setting,
and set the other device to the SL(ave) setting.
Or, set both devices on the one cable to the C(able)S(elect) setting.
When properly set, both devices will be quickly and properly detected.
Be sure that your BIOS SETUP has been configured to allow SATA devices,
i.e., not set to "disabled" mode.
Nov 05, 2010 | Intel D915GAV Motherboard
Cannot detect my sata hard drive during POST. I tried to use another sata cable but the same problem. I tried to transfer the hard drive in same mother board unit and it works fine. I tried the 4 slots...
try to use another SATA drive in this machine...if this new HD is detected by this machine...
try connect the old HD on another machine....if it cannot be read there...also.... then i am sorry the HD is OUT/dead....
Sep 27, 2010 | ASUS P5L-VM 1394 Motherboard
Bios not detecting 320gb sata drive
Double check the jumper configuration, You might also want to check the cables and ports incase that's the problem because a properly jumpered SATA drive shouldn't have any compatibility issues. Also check if *********** board supports the SATA ? Let me know if this works..thanks. Mike
Mar 04, 2010 | PC Chips M955G Motherboard
SATA Hard disk 500GB and Sata CDROM
Could be a problem with SATA drivers. Just try to disable sata support by entering bios setup if applicable.
OR
Find the drivers for sata device and install
Feb 20, 2009 | Mercury KVM800M Motherboard
My hdd sata is not detected by motherboar.
brohter you should chek you r hardisk and then check ram GOD WILLING YOUR PROBLEM WILL BE RIGHT IM RIAZ AHMED BROHI FROM PAKISTAN PLEASE EMAIL riazbrohi@gmail.com
Jan 24, 2009 | MSI K8MM-V Motherboard
Drive SATA 3.0 Gb not detected by msi 7060
3GB Sata driver? i dident know there existed so smal drivers
Anyway, if your bios dosent detect the driver u probably need to update the bios drivers.
Go to MSI site:
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=158
Instal LIVE UPDATE and let msi check you computer for laterst drivers u need to instal
Nov 20, 2008 | MSI 661FM2-LSR Motherboard
Intel Motherboard Logo
15 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
