Question about Toshiba 32A43 32" TV
Toshiba 32A43 Horizontal Bars, pop, no picture.
My friends Toshiba 32A43 Powers on and works for about 5 minutes, then horizontal lines are spread evenly across screen and it starts zooming out and the picture starts turning pink before a pop noise is made and the tube goes black. Unplugging the unit and reconnecting the power will restart the process. I have done nothing to the unit myself, but I am thinking that a high power flyback converter or something along those lines may be the problem, but figured I would ask around before diving in.
  • Douglas Teitge
    Douglas Teitge Jul 27, 2007
    You seem to be right... there is no "high power flyback converter", but there is a High Voltage Flyback Transformer. It looks like you figured out that I was referencing that... my exact wording was not perfect, but I do know the part, and "the basic components". I also have the proper tools to discharge the CRT safely.
    So thank you for your concern, but I have replaced numerous Analog/Video boards on iMac G3s (the CRT based iMacs), and I am also Apple Computer certified to do so. I have seen A/V boards (that is an Apple reference to the Analog/Video board that houses the flyback transformer) cause problems other then just a black screen.
    I guess that is maybe why I posted a question here hoping someone might actually try and help and not be a [email protected]
First of all, there is no such thing as a "high power flyback converter". There is a flyback transformer, but if it was bad you would have absolutely no picture at all. The fact that you dont even know what the basic components are suggests that you should not be "diving in" to someone else's TV. Do everyone a favor and allow an experienced tech to service the set.
Posted on Jul 26, 2007
SOURCE:
Samsung LN32D403E4DXZA works for 30-90 min. Fine, color horizontal lines appear and a clear band at the top slowly spreads to the bottom. If off a while, turns on OK, but cycle repeats. Is it TCON?
Generally horizontal bars are signs of panel issues but you could try baking the tcon board in the oven and see if that helps since it works for a few mins...sounds like a heat issue if its not that panel
Mar 10, 2018 | Samsung Televison & Video
No picture, green picture or horizontal bars
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 31, 2014 | Televison & Video
Screen become small in horizantal
The problem is with its width. Usually this will be related to faulty components in the horizontal deflection circuit; provided height of the picure is OK. Check the horizontal output section.
May 01, 2012 | Toshiba 32A43 32" TV
When we try to turn on the tv (toshiba model 32A43) it makes the sound of turning on then off and the screen stays black and a red light by the power button keeps binking
You're either losing high voltage or power supply is not producing the horizontal drive signal, Check for 130v on the collector of the horizontal output transistor, if you're missing your voltage, you have a power supply problem. If voltage is too high you have something open in the power supply such as a low value resistor. If its low, something is shorted in power supply, possibly voltage regulator ic.
Jul 31, 2011 | Toshiba 32A43 32" TV
Toshiba tv 32a43 power button flashes red and won't turn on
Check to see if horizontal output is shorted, But will have a damper diode, between the base and emmitter, will read 0 ohms. That's okay to check like that, Check for shorts between collector and emitter and collector and base. If ok, check for 130v dc on the collector of the horizontal output transistor.
Mar 26, 2011 | Toshiba 32A43 32" TV
Toshiba TV picture has become single horizontal line in middle
this problem is caused by a faulty ir of cap's . First is c408 on the board it is a 100uf @ 35v i replaced with same uf and @ 50v , Second is a 2.2uf @250v and is c410 on the board replace both and your off to the races.
BEWARE OF HIGH VOLTAGE EVEN IF UNPLUGGED
BROUGHT TO YOU BY WWW.JCEWASTE.COM
Jul 22, 2010 | Toshiba 27AF43 27" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Black horizontal bars and jumpy picture.
Yes . Some of these caps are in the secondary of the power supply and some are on the signal board around 5v and 7v supply lines on the signal board . The 5 & 7 are mounted on heat sinks and the caps are right around there .Generally either 2.2uf or 4.7uf or the 47uf . Good luck
Dec 19, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Toshiba 32d46 single horizontal line in center of tube
Hi. Check the frame output IC for dry solder joints.
Sep 15, 2007 | Televison & Video
Toshiba 32A43 32" TV Logo
164 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
