Question about Pioneer SD-P55A3-K 55" Rear Projection Television
Words don't line up??
I have a pioneer sd-p55a3 and it has like a double image and when words come on they don't line up I was told to set the convergence I look in the menu and did not find any way to set this should it be there or am I just missing it? If I do find it and that don't work what more can I do to fix this? I would like to keep this tv it is still in nice shape
Thanks for your help mmt13
  • bensonlkrad Apr 26, 2009
    i have the same problem but als a lot of red hazing around images
  • 2,920 Answers
Call someone out to reconverge it for you it shouldnt cost alot and it will get the picture right again
Posted on Jan 28, 2009
No picture on my pioneer TV model SD-582hd5
The problem is on lamp try to replace it to get back the picture..
Feb 23, 2012 | Pioneer SD-P55A3-K 55" Rear Projection...
Hi. our problem with our pioneer sd-p55a3 is that it wont turn on. when you press the power button it clicks to turn on, but then nothing happens. can you help us?
Look for Blowed Fuse on the Power supply board located in the middle of the board 6.3amps and if its OK then replace Both of the STK ICs Black ICs will have PN STK392-110s use 150s Mats has them these ICs retail for $55.00 each your cost $9.95 1-800-628-1118
Sep 18, 2010 | Pioneer SD-P55A3-K 55" Rear Projection...
Suddenly a curved line appeared in the upper left and lower right corner ....and words like "muting" and lower right words are doubled with a red virtual image....the main picture in the center is pretty...
Convergence problem---set uses two of the STK-392-560 convergence chips.
Both will have to be replaced and set adjusted with remote.
Total parts cost on EBAY under 25 dollars.
I can tell you what is involved.
see attached photo of typical convergence problem and typical convergence chip.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Sep 03, 2010 | Sony KP-51WS500 51" Rear Projection...
The colors are all there but there is a double image. Like a blue or yellow outline around everything and words are doubled. I think it is a convergence problem but I don't know how to fix. Please help.
It is convergence problem---set uses either 2 or 3 chips for this (most use two of the STK-392-110 OR 150 CHIPS.
Total parts cost on EBAY would be under 25 dollars.
This can be a do it yourself job if you can solder and have some skill.
See attached photo of convergence problem and typical convergence IC.
If this told you something you did not know, rate this solution as I do this here for free.
Aug 24, 2010 | Hitachi 60DX10B 60" Rear Projection...
My pioneer sd-p55a3 projection tv stays on for 5 minutes and then fuse for projector burns out
probably the solder connections on the convergence board.. solder it up good and it will usually stop blowing that fuse..
what is the fuse #?
let me know if i can be of further asistance
Jun 08, 2010 | Pioneer SD-P55A3-K 55" Rear Projection...
Sd-p55a3-k/kc this tv does not turn on
Th convergance amps have failed you will half to replace them, or have it done parts are around 70 dollars not and easy fix on a pioneer time consuming
Dec 10, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Hello, I have an older Pioneer SD-P55A3 projection tv. I have a problem where the picture at the bottom of the screen appears distorted or, more accurately, "warped". There is yellow and blue that does not...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
Mar 16, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
My Pioneer 55 inch screen tv SD-P5553 has a solid black horizonta
This sounds like a picture mode issue. You maybe in a ZOOM mode. Try adjusting your set to FULL mode. If you are using a Sat receiver or cable box, some of these may have picture viewing mode as well, wich may need to be set in FULL or NORMAL viewing mode.
Good Luck!
Jan 18, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer tv
This is a common problem with pioneers. try resoldering the vertical output Ic that should remedy the problem. if not the vertical IC may be faulty
May 27, 2008 | Pioneer SD-P55A3-K 55" Rear Projection...
Purchasing STK's. Who is Reputable?
you get what you pay for. At they STK392-180 is 29 and change . AND yes replace them with the 180 as the 110s are not powerfull enough. Good Luck
May 27, 2006 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer SD-P55A3-K 55" Rear Projection Television Logo
113 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
