Question about Canon PIXMA iP4600 Color InkJet Photo Printer
Canon pixma ip4600 black ink problem
I am printing only text (mostly on the normal intensity) and the pixma ip4600 is "eating" the larger black ink tank - PGI-520 (which is used for photos as canon says), while the smaller black ink tank (CLI-521) is unused. Now the PGI-520 is empty - and I urgently need to print something - can i print without it and how to "force" the canon to use the CLI-521?
Another question is: how to reset the ink levels without an ink resetter for this model?
  • 159 Answers
The PGI-220 is the larger ink tank and is filled with standard black ink. The PGI-221 black cartridge is the photo black. There is no way to force the printer to use the photo black cartridge (skinny one) to print documents. The photo black cartridge is only used if you print a photo. I own a Cartridge World ink refilling shop and I can't refill these cartridges yet. There is no way to reset the ink level chip without a resetter and any replacement chips you find on the internet are technically violating patent law.
Posted on Feb 03, 2010
Canon Pixma IP4600 won't print black on disc but will print black alright on paper.
go to http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip4600#ServiceAndSupport
Oct 28, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
Canon IP4300 - the two black ink cartridges
No!
The large cartridge is used for text only printing.
The smaller black cartridge is used for black in images such as pictures.
You have a "C (cyan) M (magenta) Y (yellow) and B (black) color system. This actually saves the color inks for you. If the Black was not there, you would need to make a composite black from the color inks.
Don
Jan 31, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Why does the printer use one black cartridge and not the other? Is there some way of instructing it to use the left hand one too?
the pixma printers use the large black tank in most modes like text and standard (default) or fast photo printing .. thats most economical when you are using just plain paper .... it will switch to the small black tank only if you select "High" quality mode .. that black matches the nature of the color inks much better and results in really good color pictures if you are using Gloss or Matt high quality photo paper .. you can select the quality level by the following ... when you start to print, a window comes up where you can select which printer you want ... at the right of this window is "preferences" .. click that .. now select the type of paper and "High" quality mode .... now the printer will slow down but will provide really nice results and it will use the small tank black ink instead of the large tank ....the small tank is only used for "high" quality photo prints which is only needed for high quality photo paper .. if you havent tried that yet you might want to get some glossy photo paper (either Canons or Costco has great stuff if you want a lot, like 150 sheets) but most glossy paper will work except colors might need tweeking for some ... print a nice photo in the high quality mode and you should be really impressed .. and you will be using your small black ink tank .. you might want to make the first few pictures small (2x3 inch) untill you are sure everything is the way you want it .. i usually print in the top left corner first .. then reinsert the same paper and try again right next to that .. i do that until i get the colors perfect .. then i print big .. 5x7 or even 8x10 on a new sheet... the high quality mode can be selected for just plain paper and it will use the special black ink but it doesnt result in a better picture .. so no point in doing that unless you want to experiment .. if you never print high quality photos then you will never use the small tank black ink .. it will still be used up eventually because of normal head cleaning the machine does automatically .. ...
grey scaling does not select the special ink unless you select "High" for the quality setting .. then yes you can print using that small tank black ..again it will buy you a lot if you are using High quality photo paper ... almost nothing for plain paper but at least it will allow you to use that ink .. ..
Dec 13, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Printing B&W on a Pixma MP800 with empty color cartridges
no you cant print with emapty colour catridges you have to install the other full catridges.
Nov 23, 2009 | Canon Pixma MP800 All-In-One InkJet...
Change cartridge printer selects for black
Simply put...you cannot. The smaller cart is the dye black, which is used for picture printing. The larger is the pigment black which is used for text printing. You could try printing text as artwork, but i'm not sure this will work, besides, dye ink will bleed on regular paper and not look so crisp.
Aug 16, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer always uses large black & runs out, cant isolate other
The BK5 is for black text only. The other black ink is used for shades of black/gray together with the three basic colors in printing color photos. You cannot use it to print black text.
Jul 29, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
How do i change to the smaller black ink tank on the canon pixma MP630 when the large one has run out? Thanks, Lynne
You cannot change to the smaller cartridge when the larger cartridge (PGI15BK). The smaller cartridge is used for photo printing along with the Y,M, and C cartridges. You must replace the larger cartridge to be able to print text.
Jul 09, 2009 | Canon Office Equipment & Supplies
Canon PIXMA iP4600 - error 6A80
Hello someone else here had this problem, this is what he posted: "Same problem with a Canon MP540 fresh from the box. Turned out to be the print head unit was not returning fully to the home position ie extreme right. My Fix : When the scanning unit cover is raised the print head unit moves left for access, look in the vacated area to the right, in particular the small black sponge where the head normally parks. I found a small spring jammed in beside the sponge, removed it and all is well. Don't know what the spring was meant to do but everything is working fine without it.On the MP540 the head unit now glows red, presumably meaning all is well... "
Jun 14, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Ink cartridge running low will it default small cartridge
It won't default to the small one...I emailed Canon support; this is the response I got.
The reason for the two different black ink tanks is for the different types of printing your unit is capable of. They are not intended as backups to each other. The larger black tank is pigment based, and is primarily used for standard black text printing or output. The smaller black ink tank is dye based like the color inks, and is used for photo and graphics output. They are designed to complement each other, allowing the printer to produce the best possible black text output or photo quality as appropriate.
Feb 25, 2009 | Canon PIXMA MP610 InkJet Printer
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
1,426 people viewed this question
old marine
old marine
