Question about Quasar VM-L152 Camcorder
The tracking is off when I play back video.
The camera seems to work but when I play back, the picture rolls continuously.
    President:
  • 814 Answers
You need to use a head cleaner. Buy a good head cleaning tape and run it for about 10- 15 seconds and see if you problem clears up. Check your tape transport for dust and dirt and clean it out with a small can of compressed air. Checkk the tape heads and see if they are worn out. Usually looks like a black strip in the middle of the head. You may need to replace the heads. I hope this information help you with your problem.
Posted on Jun 11, 2009
I have recently acquired a sony analog video camera model CCDF-201 this camera plays back previously recorded 8 mm tapes but when I try to record with this camera the screen is running lines through the...
hi!
The problem is with the CCD which is the sensor when it is defective the pictures get disturbed also.Please replace the CCD from any service center,
Aug 27, 2010 | Sony Video Cameras
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
Picture rolls on playback
Try cleaning the heads, but it seems like the heads may be faulty, you might need to replace the vcr, they don't cost much these days, the repair might cost more than a new vcr these days.
heres a cheap headcleaner, look for one at local shops, wallmart bestbuy and so on
http://www.pcconnection.com/IPA/Shop/Product/Detail.htm?sku=7632166&oext=1038A&ci_src=14110944&ci_sku=7632166
Sep 24, 2008 | Panasonic PV-V4021 S-VHS VCR
Rolling of picture
It seems your Handycam has " Pal " system and you are watching it on " NTSC " TV. If your TV is Multi Color System, please select Pal color system. Hope this info will be helpful for you.
Aug 17, 2008 | Sony Handycam CCD-TRV68 Camcorder
Tracking seems off
I have had the same problem. There is no way to manually adjust the tracking on this Hitachi, or on most 8mm cameras, for that matter. I copied all of my more recent tapes to DVD first (2 copies of each) and then I went to the oldest tapes, which for some reason were OK. When I got to one tape that gave me trouble, I just let it play in the camcorder for about an hour. It adjusted its own tracking so that the picture was OK. Then, I rewound the tape and copied that one. I still have 2 tapes that will not adjust. I am going to send those out to a copying service. I hope they can adjust the tracking and make the copies I need.
By the way, I used this camera and a Panasonic DMR-E55 to make the DVD copies.
Jun 04, 2008 | Hitachi VME545 Camcorder
Rolling picture on TV while playing back Hi8 tape on TRV460
Hello richiehere,
Check and correct Color System of your TV set. I think you have Multi-Color System TV set and Its not match with your camera system.
May 23, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Why wont it play LP taped tapes?
Tracking is very sensitive on hi-8 tapes in LP mode. This recorder will record and playback in LP mode. It is however recommended that if you record in LP mode that you use the same camera to play it back, that it was recorded with, or you might have problems.
Also from what I can find online, the TR427 is just an video8 camera not a Hi-8 so if you are trying to play Hi-8 tapes on it, it won't play right.
Nov 03, 2017 | Sony Handycam CCD-TR427 Hi-8 Analog...
Playing slp mode picture rolls
the video and control heads are probably dirty. a video cleaning tape might work, otherwise you will need to get a proffessional to clean if for you.
Mar 25, 2008 | Philips Magnavox 20MC4304 20 in....
Possible causes: the sync signal head is not recording, there is a mismatch between the capstan motor speed and the video head speed, or one of the sync circuits has a fault. Typically, if the picture rolls up or down, it's a vertical sync problem. A horizontal sync fault or tracking mismatch will cause the picture to tear sideways.
Try cleaning the sync head (one of two heads separate from the video head drum; the other is the audio track head), but don't be surprised if doesn't solve the problem.
Feb 25, 2018 | RCA CC617 VHS-C Analog Camcorder
Quasar VM-L152 Camcorder Logo
85 people viewed this question
Top Quasar Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Michael Allcock
Level 1 Expert
Tom Chichester
Are you a Quasar Video Camera Expert? Answer questions, earn points and help others
