Question about Magic Chef CMV1100 Microwave Oven
Microwave magic chef
The microwave runs but doesn't heat and sometimes its works for a month or so without a issue, i don't know if one of us are pressing something somehow we shouldn't but none the less this problem is on going, thanks for your time
  • bgaassoc Feb 16, 2009
    My microwave won't cook. Lights work, sounds like its on. When I bring out what I want to cook its still uncooked.
    Thank you,
    President:
  • 1,214 Answers
It sounds like a microwave circuit problem, and it's very likely a bad rectifier or capacitor. It might be the magnetron.
I would stop using the unit and get it repaired before a more expensive component is damaged.
Posted on Jan 28, 2009
Magic chef not heating
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Jan 21, 2013 | Magic Chef Over the Range Microwave. 1.6...
Turntable
The turntable motor is defective, since it is 6 months old your warranty should cover the repair or replacement of the microwave oven.
Apr 04, 2012 | Magic Chef Microwave Ovens
The microwave keeps running without turning off but it's not heating anything. It still works when you press the buttons though.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 07, 2010 | Magic Chef MCD1611ST Microwave Oven
My MAGIC CHEF MCO153uw stopped working. It heats
This sounds like a thermal protector is turning the microwave off. If I were to hazard a guess, it would be the magnetron (produces the microwaves) is overheating causing the shutdown. If the fan was not running it would create the same condition by causing the magnetron to overheat.
Nov 14, 2017 | Magic Chef CMV1000B Microwave Oven
Magic Chef Microwave runs but no heat produced,
heatman101
uitot
May 11, 2010 | Magic Chef CMV1000B Microwave Oven
I just installed an over the range Magic Chef microwave and all controls seem to work properly however, it will not cook or heat anything. Am I correct in assuming the magnatron is faulty.
Sometimes there is a separate fuse for the magnatron circuit. Sometimes the fuse is the culprut, and sometimes it is the control board. Usually when magnatrons fail, they smoke or go bang or both.
I would look for a blown fuse first, and then look for a factory authorised service center.
Best of luck.
Jan 20, 2010 | Magic Chef MCD1311ST Microwave Oven
No heat on magic chef microwave
Check the door safety interlock switches.
Dec 29, 2009 | Magic Chef MCD1311ST Microwave Oven
Magic Chef MCO153UWF
Tin foil or steel plates in a microwave will burn it out. I suspect it is or has burnt out. Never put anything steel in a microwave.
Mar 12, 2017 | Magic Microwave Ovens
MICROWAVE WILL ONLY HEAT ON CERTAIN SETTINGS. how do i set the heating instructions?
I have a Magic Chef model MC0160UQ. Within 2-3 minutes of heating food it shuts off completely for about 5min. Also, when I select the low fan it does not work, however the high fan works. Please assist with these issues if possible. Am I able to fix or adjust the magnetron myself since it may be overheating? or what should i do?????
Jul 18, 2008 | Magic Chef CMV1000B Microwave Oven
Magic Chef CMV1100 Microwave Oven Logo
186 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
