Question about Lexmark X2350 All-In-One InkJet Printer
Lexmark 2735 power button flashing
Hi guys My printer had a paper jam and paper freed. Ever since power light flashes continuously and paper wont print at all. Any ideas how to fix this please?
Unplug the Power Supply from the Printer..........
Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so
that it should become like a thin long strip........ Now Insert that Envelope on the left side
corner of the Printer and move it from right to left and left to right as fast as u can for
about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the
catridges and Turn on the Printer.........
Good Luck..........
Posted on Jan 28, 2009
Error p1500
The printers first error code show all lights flashing:
Flashing Ready'Data
Flashing Toner Low
Flashing Load'Remove Paper
Flashing Paper Jam
Flashing Error
Flashing Press Continue
By pressing continue twice to get to second error codes the lights show:
Flashing Ready'Data
Off Toner Low
Flashing Paper Jam
Flashing Error
Pressing continue twice more shows:
Off Ready'Data
Flashing Toner Low
Off Load'Remove Paper
Off Paper Jam
Off Error
Off Press Continue
Pressing continue twice more brings back to all lights flashing
The computers ( I have tired more than one with diff USB and A parallel cables) do not see the printer as being attached. My toner is half full. I checked the internal power board in base of printer and the fuse is good. The error should not have anything to do with being connected to a computer or not because when it was working and not connect to a computer it would not blink all the indicator lights (If I remember correctly, just the Press Continue light would be lite).
Information I have found so far:
  1. http://support.dell.com/support/edocs/systems/p1500/en/index.htm#online_documentation
o Under PDF Documents Owner's Manual(English) (.pdf) (1.33 MB) shows very little about the indicator lights.
o Under HTML Documents User's Guide shows more information about the indicator lights but mentions nothing about the secondary error codes.
  1. The Lexmark E321/E323/E220 are very close cousins to the P1500 and on Lexmark's website the manuals have more info on secondary codes but nothing that matches my error.
Information I am guessing could be the problem:
  1. The fuser has gone out (need to know how to check) Why else would they sell the fuser if it didn't go out regularly Part Number: 56P1053
  2. Clutch Assembly I'm not sure of the accuracy of the info on this page.
Mar 12, 2014 | Canon Office Equipment & Supplies
Lexmark x2600 i have ink and ervything my paper isnt jammed but everytime i try to print the button next to the X button keeps blinking orange
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
2. Open the printer cover and remove both the cartridges.
3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check the light status.
8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
10. Load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 21, 2011 | Lexmark X2600 InkJet Printer
The orange paper light with the arrow keeps flashing and my ink cartridges wont come to the center
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
10. Load some paper. Try to print again.
Aug 18, 2011 | Lexmark X2670 All-In-One Printer
Lexmark X75 not working - flashing power and status light - no paper feed.
  5. Unplug and re-plug the printer into the power source to reset it.
  11. Try to print again.
Jul 26, 2011 | Lexmark X75 All-In-One InkJet Printer
What do the flashing light mean on a lexmark E260D. please help
We would like to know more about the flashing lights you're referring to. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
For us to give the common light sequences, please provide us information which light is flashing on the printer.
For further assistance, please call Lexmark Technical Support.
Jun 24, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Lexmark x2500
There 3 light on the printer that able to indicate to user when problem occur. Find your printer error accordingly as below and may solve your printer problem.
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
Hope this help.
YBC (/\)
Feb 05, 2009 | Lexmark X2500 All-In-One Printer
Wont Print
it has a paper jam. just press the paper feed button.
Aug 31, 2008 | Lexmark X1290 All-In-One InkJet Printer
Lexmark x1270 printer power button blinking won't print
I had the same issue with my Lexmark X1290, I solved it by opening up the device, so the ink cartridges should pop, they didn't so I pressed the power button to switch it off, and then switched it back on (with the device open!) and all the paper flowed out, the flashing stopped and it could print again. Good Luck!
Feb 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark P4350
Solution:
I have a Lexmark and it says that there is "No Loaded Paper" some times and when you click ok it keeps saying it. If the power light is flashing on the printer - try this suggestion.
Suggestion:
  1. Press the power button (Which will turn off printer.)
  2. Wait till flashing stops and printer is completely off.
  3. Press the same button which will turn on the printer.
  4. The Printer should automatically go back to printing.
  5. If it does not - Manually try printing by your self.
Dec 04, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X2350 All-In-One InkJet Printer Logo
217 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
