Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a GE SpacemakerXL Microwave Oven Model JVM1340. The pad is unresponmsive. When pluged in I get a line of eights and then get the message F 3.
  • 124 Answers
Thanks for the opportunity to help! To see if this fault can be cleared, do the following:
  1. If your unit is plugged into an *outlet (most times, this is located over your microwave in small cupboards).
  2. If it is, unplug the cord and wait about 30 seconds.
  3. Plug your microwave back in and see if the panel now works.
  4. Go through all the initial setups such as setting the time.
  5. If the fault does not reappear, then you are good to go. If the fault reappears, you will have to call service or replace the product.
*If your unit is hardwired, find the circuit breaker and turn it off for 30 seconds, then turn the power back on.
If you find my assistance helpful, please rate my service. Thanks for using FixYa.com
Posted on Jan 28, 2009
Solution-GE spacemakerXL microwave oven model:JVM16505H01 mfg.date:feb.2005
Sounds like you have a bad smart board, you can try unplugging the unit for five minutes and then back in, if you are lucky this may correct the problem...good luck
Feb 18, 2014 | GE Microwave Ovens
I have a GE SpacemakerXL Microwave Oven Model JVM 1350 The fan and the light works, but the microwave is not working and the screen says
There are two possibilities, one of the door switches has malfunctioned, usually caused by food partical buildup, more than likely. or there is an issue with the microprocessor control board, less likely.
Mar 11, 2012 | GE JVM1350BW/WW/AW/SY Microwave Oven
My Microwave JVM1340 runs but does not cook anything. What part should need replacing?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Aug 31, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Need exact dimensions of GE JVM1460
If this link does not work paste it into a search window and then click the link:
JVM1460WA-GE Profile™ SpacemakerXL 1.4 Cu. Ft. Microwave Oven
GO to this link: http://www.geappliances.com/service_and_support/literature
Then type in the model JVM1460SA001
15 & 3/4" high 16 & 1/2" hole required for vent connection in rear
15" deep
Needs a 30 inch wide hole for installation
Thanks for choosing FixYa,
Kelly
Aug 14, 2011 | Microwave Ovens
heatman101
Apr 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
I have a GE Spacemaker XL Microwave Oven Model JVM 1430. The pad is unresponsive. When I plug it in I get a line of eights and then the message F 3. What can I do to fix this problem
F3 - ( shorted key panel ), will occur if a shorted key panel is detected continuously over 60 seconds.
Note: It will take a minimum of 1 minute of run time before the F code will be displayed.
P/N WB27X10165
Jan 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
166 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
