Question about GE 168947 Toaster Oven with Convection Cooking
169068 GE Toaster Oven - no heat
What could be wrong with my toaster oven. The power light come on but not inter-workings "noise" and therefore no heat. Is it an easy fix or should I pitch it. It was a gift more, 3 years old.
  • 40tools Mar 18, 2009
    same problem, I tore mine apart and the thermal switch was corroded. I will give a search for the part but it will probably be cheaper to start over with a new oven.
  • 267 Answers
Remove the plastic side where the controls are . if you see a broken wire you might be able to repair it otherwise theres no parts made for it ,so no matter how simple the broken part is .....there is nothing that can be done about it ........ WELCOME TO THE WORLD OF "MADE IN CHINA"
Posted on Feb 05, 2009
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
Need heating element (upper) for GE168947 toaster oven
You should be able to install a new replacement element or a used element from another GE168947 toaster oven.
Jul 03, 2012 | Toaster Ovens
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
Do you still need top elements or do you still have your GE 169104 oven?
Apr 16, 2010 | GE 168947 Toaster Oven with Convection...
Toastmaster Toaster Oven 357 is not heating when door is closed?
Mine just broke too - it won't heat - everything else works - lights, timer ect. but no heat can't cook
without it - love my oven - any solutions ( I guess it's the heating element ) Hope I can get a new one.
Aug 29, 2009 | Toastmaster 357S Cool Wall 1400 Watts...
I have a new GE Covection Toaster Oven model 169127/169140. My question is should this oven's heating elements shut off periodically when the set temperature has been reached?
YES this is normal it is how it regulates temp by cycleing the elements ......................Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 01, 2009 | GE 168947 Toaster Oven with Convection...
Top element broken
Oster 6233 toaster oven top heating elements don't work
Nov 11, 2008 | Toaster Ovens
GE 168947 Toaster Oven with Convection Cooking Logo
774 people viewed this question
Top GE Toaster Ovens Experts
Mack Baxter
Michael Teter
Michael Teter
Level 1 Expert
stanley austin
stanley austin
Level 1 Expert
Are you a GE Toaster Oven Expert? Answer questions, earn points and help others
