Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Voip how to reset the linksys voip 2 port
  • 55 Answers
Hi
Warning This will RESET to FACTORY DEFAULT
There should be reset hole with a button in it if you press this and hold it in. count to ten then release, this will reset it to factory default setting.
If you are not wanting factory reset you will have to login to the linksys the default IP is 192.168.1.1 login name admin password admin.. that is you havent change it. and from there you can find your settings and change them..
Good Luck
Posted on Jan 28, 2009
2 Suggested Answers
SOURCE: repair of vonnage router RT31P2
what is the cast of this router?
Posted on Jul 18, 2008
Need driver and firmware for LinkSys RTP 300, or how to set it up for simple home network with interneton the PC and laptop as the 2nd computer.
No drivers are required since there is no actual installation to to the computer. Connect the ISP modem to to the main LAN network port. Then use any available port to access network. 1.Power 2.Main drop. 3.Network. That's it!
If the router is used, you may want to reset custom settings by, holding in the reset pin till it cycles.
Advance setup.
http://www.cisco.com/en/US/docs/routers/csbr/rtp300/installation/guide/RTP300_UG.pdf
Oct 16, 2012 | Linksys Rtp 300 Broadband Ethernet Voip...
Hello,I have connected a linksys voip
Hello dandashi77,
I am using a Panasonic DECT 6.0 Series cordless phone. However, the VIATalk.com VOIP Services uses a LinkSys PAP2 adapter which can work with any type of phone. A Broadband connection is required to use the VIATalk.com VOIP service. Setup is very simple and the instructions areeasy to follow. Just a few simple things to do.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jul 30, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
IP ADDRESS OF VOIP PHONE ADAPTER 2 PORT PAP2NA
doanload colosoft netscan, when you have it plugged into the network, run netscan on a computer thats on the same network....that'll find it for you, if that doesnt work give me the specs on the phone and ill check the manuels..
Jan 22, 2009 | Linksys VOIP PHONE ADAPTER 2-PORT (PAP2NA)...
Connect my phone adapter
You need to register/subscribe to a VOIP provider first like Vonage and the likes. Then you need to register through your VOIP provider the phone ports of your router. ISP is different from VOIP.
Oct 24, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Linksys SPA2102 interfearing with winmx/360 sharepro, frequently resetting connection
If your planning to connect the phone adapter behind a router make sure that the following ports are open/forwarded on the router; UDP ports 5060-5061, UDP ports 16384-32767 take note that 5060 and 5051 one are SIP ports and must be assigned to the IP address of that was assigned to by the router to the adapter or the IP that was manually configured on it.
I found a link that could help you check the setting on your linksys phone adapter
http://www.voipvoip.com/linksys-pap2/
Hope this will help you solve your VOiP problem...
Regards,
Sep 11, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Repair of vonnage router RT31P2
check if you are able to go online with this router.. if not contact linksys, if you are able to go onli ne and not able to make call, contact vonage..
Dec 12, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
79 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
