Good morning. my hpD1460 driver is lost as well as i am now forced to use a different pc and therefore now needs to again set up the use of my printer. Please advise on how to use this medium to overcome this setback. Thanks.
    President:
  • 1,073 Answers
Hello there M8!
No probs:) follow the limk below and you will find that you seeking for
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=2510644&lc=en&cc=us&dlc=en&lang=en&cc=us
Good luck to you!
Please take a minut to vote
Nic
Posted on Jan 28, 2009
Linksys wrt101 help
There is one thing that you can do. Reset your router and enter the default password which came with your router. Usually username:admin password: admin. If that is not the default password, you can search the Google for your router's model default password. The biggest problem that you will have with this method is any custom configuration that you made on the router will be lost. Therefore you will need to rewrite them again.
Jun 21, 2014 | Cisco Computers & Internet
Good Morning, I am from Hyderabad. Whenever i
The signal level is down or the earth lead may be faulty in the vga cable arangement.
Try a different pc and see if the signal level is the same for both pc's. Then try a direct cable again. Then try a different spliiter if you can get hold of one.
Sep 14, 2011 | Sony VPLFE40 LCD Projector
I lost my recovery partation and I don't have a recovery cd for an asus seashell eee 1001p, how can I do?
Hi you will need skillful guy to restore your PC Operating system if you had reformatted your hard drive. To restore your O/S without having your recovery CD is to ask from your vendor a copy of it and re-install again. You can do it by having an external DVD driver, change the boot sequence in start up and presto you can reload again your O/S and other applications. Don't forget btw to load the driver in order your PC to work properly.
Jun 21, 2011 | ASUS Eee PC 1001P Netbook
What can i do when water is inside my mp3 player, then i lost it for a month. when i found it , i immidiaetly plugged it into my computer, it started working. i let it charge. when i took it out, it...
Good morning, afternoon, evening or night; whatever time of day you are viewing this post. Thank you for choosing FixYa to assist you with your problem. Your MP3 Player has been exposed to water, then it gets lost, you find it and immediately plug it into your computer for it to charge and start working again, then it shuts off after you unplug it from the PC. I don't know if you know this or ever read it in user manuals, but they tell you not to expose your electronic device to liquid substances. This can cause product failure as well as harm to yourself or others. I'm surprised it's still working when you plugged it into the computer. I had a flash drive that went through the same experience as your MP3 player: got lost and was exposed to rainwater, then was found later and started to work again once it was plugged into the computer. Later on though, the computer failed to recognize it and it eventually stopped working. I'm thinking the situation with your MP3 player is that the battery or a driver controlling battery functioning, is defective due to water exposure. The driver that controls the PC launch up, may not have been exposed to it as much. You could try opening your MP3 player (if it can be opened) and try to drain all the water out of it, then put it back together and try to turn it on again. If that doesn't work, plug your device into the computer and go to the device manager on your PC. If your computer recognizes the device, go to its properties and click the driver tab. Click "Update Driver" to see if a driver update is needed. If the driver is up-to-date, try uninstalling the driver, then reinstalling it again. If your device is not working properly after this. Then the battery, driver or other electronic circuitry inside of your MP3 player is defective. You can try to replace the battery, if it can be, to see if that makes the difference, but I'm pretty sure your MP3 player is defective now. I'm sorry for the inconvenience, but thanks for choosing FixYa to assist you with your problem. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
May 23, 2011 | Audio Players & Recorders
My kid pressed f9 and the the mouse got frozen and i dont know what to do
first if the mouse did not get back after restart ..it means that it is probably disabled...(Im not sure if it is from F9) ...if we talk about an external mouse the issue probably got solved after the restart ..if we are talking about the touch pad...it probably need a different approach ....Go to bios setting by pressing F2 on start if it is a laptop ..and del key if it is a desktop ...in the Bios settings look for the optimal factory defaults ..and activate it by selecting and pressing ok (enter ) than save the changes with F10 and enter ..This action will reset all bios settings including any disabling ...by forcing the computer to recognize again all devices..
If it is an external mouse..and USB based...you probably need to run the driver disk again ..cause the issue may be from a defective driver ....
Jun 25, 2010 | Toshiba Satellite M35X-S161 Notebook
Lost my disk.have a different pc.. how do i set it up?
Check the website for the printer. You should be able to download the latest drivers there. Or, search the web for drivers for that printer.
May 10, 2009 | Office Equipment & Supplies
Microsoft SideWinder Force Feedback Wheel
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Jan 25, 2009 | Microsoft SideWinder Force Feedback Wheel...
Download the software of scan benq 4300 or the setting
pls help me i lost my scanner 4300 cd, and i need the soft to be able t o use it again
Oct 27, 2007 | BenQ Scan to Web 4300U Flatbed Scanner
Printing from 2 different pc, drivers installed on the server, get different quality
I think that quality settings is different for each user. If your printer have network card, pleas install printer with TCP/IP port in every PC, not from server, more job, but less problems.
Sep 15, 2006 | Konica Minolta magicolor 5430 DL Laser...
jasbo
jasbo
