Question about Frigidaire GLET1031 Top Load Stacked Washer / Dryer
Trying to trouble shoot problem with Frigidare stack top load was
I cant seem to get the cover off of the washer, do I have to remove the dryer to do this?
....there are also two screws that hold the top lid down, they are located front corners of the lid
Posted on Apr 29, 2012
There are 2 screws on the bottom/front of the cover to the washer. Remove the screws. Near the top/front of the cover is a seam; insert something flat in the seam (such as a screw driver blade, covered as to not scratch the finish)and pry the cover downward. This worked for me.
Posted on Jun 10, 2009
No heat for my frigidare fex831cs top load stacked washer dryer
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Feb 17, 2014 | Frigidaire FEX831CS Top Load Stacked...
How to replace door switch on washer
The slanted panel between washer and dryer remove lean in look behind top of washer on each side the is a clamp remove screws you should now be able to remove top cover of washer and access switch.
Feb 05, 2014 | Maytag LSE7806A Top Load Stacked...
Frigidare fex831fs2 washer fills but does not run
1. sounds like the drum has had it it happened to one of ours can be fixed though
Jan 30, 2012 | Frigidaire FEX831F Top Load Stacked Washer...
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
I am trying to find the right dryer belt for FEX831FS1
available through sears but the part number is
134503900
16.00 dollars
Oct 09, 2009 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool Twin Thin - Water Leak
It sounds like you have a bad pump. If the bottom of the washer is not solid just lean it back and take the pump off. There should be a streak of water stains on the inside of the pump if it is bad.
Nov 17, 2008 | Whirlpool LTE6234D Top Load Stacked...
Maytag Neptune stacked front load MLE2000AYW
I'm trying to remove the top cover in order to relace one of the fins inside the drum. The screws came loose and let go. I'm struggling to get the top off. Which screws in the from need removed to release the front? Thanks.
Jul 13, 2008 | Maytag LSE7806A Top Load Stacked...
Stacked Maytag Neptune - Accessing Inertial imb/Upper tub disp Switches
The switches you are referring to are set-reset. These rarely have a fault. Normally the machine control board is the faulty component. How did you determine that these switches are faulty ?
The safest way to access the upper portion of the washer is to remove the dryer. Another method is to remove the "complete" washer front and the control panel. This will give you access to the top of the washer tub.
Jan 04, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Washer thumper
The thumping could also be a belt issue if it has a flat spot in it, especially if its a Frigidare Hybrid GE. To get to the element, sorry to say it, but will have to remove the drum and front of machine to get to it. Ohm out all the thermostats and thermofuses first. If it has the round element behind the drum (which it should) check the heater wire for breaks. If its a true GE it will have two wires, Frigidare Hybrid will only have one. Good Luck!!! Jim
Sep 03, 2007 | GE WSM2420T Top Load Stacked Washer /...
Frigidaire GLET1031 Top Load Stacked Washer / Dryer Logo
168 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
