Question about IBM ThinkPad T41 Notebook
Hp zx7000 laptop hangs on startup hp logo - IBM ThinkPad T41 Notebook
  • Anonymous Mar 24, 2014
    when i start the laptop then i see the logo of vostro and hanged.
  • 73 Answers
Try starting it in safe mode. Instructions here:
http://www.bleepingcomputer.com/tutorials/tutorial61.html
If it boots in safe mode, use msconfig to disable all startup items, then selective enable things one at a time until you find the program or driver that might be causing it to hang.
Instructions here: http://support.microsoft.com/kb/310560
If it will not boot into safe mode, you will probably need to try a repair install of Windows. You may want to consult a professional for that, depending on your skill level.
Posted on Feb 07, 2009
My laptop turns on but it goes to the main screen and it shows the HP logo, the goes off and goes back to the HP logo. It does it over and over again. Help.
turn on laptop press and release continually F8 key if a screen comes up select Launch Startup Repair choose any option you think may work
Jul 13, 2016 | HP Computers & Internet
On startup os logo hangs up
Is not compatible with your device
Mar 20, 2013 | HP Compaq 6730b Notebook
My Acer Aspire 5732Z laptop hangs up on the Acer logo starup screen every thing stopped even cant enter the the bios hitting f2 or many other i tried
Remove ALL media, DVD, CD, USB. Unplug, remove battery, plug in, reboot. Try a system restore/recovery. At boot tap ALT+F-10 repeatedly.
Jan 25, 2013 | Acer Aspire Computers & Internet
HP 4530s hangs at HP screen
Sub out the ram memory one at a time, next remove the hard drive and reseat it back in place, if none of these work try your recovery disc if possible, no change! have the hardware tested for possible replacement.
Jul 02, 2012 | HP Computers & Internet
Hp pavillion dv5 not booting,turns on and hangs on the hp logo. not responding to any key commands.
Mine did that but its power dvd9..something like that... but it wouldnt work... so i kept logging off then turning it off..i did that twice and it finally worked.. i wanted to watch a movie **** it!! <----yes, i know...simple but who knows... maybe it will work for you too??... i hope you get your dvd working.. :)
Dec 17, 2011 | Computers & Internet
Pavilion does not boot. Lights on strip below screen flash on and off. HDD drive does not come on
-If you are not able to boot in Windows but still able to get error codes like from windows you can just reinstall the Operating system using your recovery discs
-If there's no display at all even the HP logo upon startup its a motherboard issue
- if you are able to get the hp logo in startup but not able to go to windows its a RAM issue
Dec 29, 2010 | HP Computers & Internet
My HP compaq nx6110 windows xp sp3 hangs at boot
Take a look at this post that deals with a HP nx6110 laptop with random freeze ups. If the described symptoms also happen on your laptop. If you do experience random freezeups or slow DVD you're facing the same FSB chip problem. All peripherals, USB ports included, are connected on the Front Side Bus. Poor soldering causes intermittent contact which in turn results in hanging, slow, or totally non bootable (stuck at HP logo) laptop. Hope this helps.
Nov 14, 2010 | HP Compaq nx6110 Notebook
I keep getting a service hang report, it says HP CUE DeviceDiscovery failed upon startup. When I go to windows reports and solutions it says a minidump.MDMP error.
change the following services.
Click on the Start button, then type "services.msc" in the "run" dialog box and click OK.
in case of vista/win7 type it in "start & search" box(you can find it once you click on windows logo)....
Set as "Automatic" the startup type for:
-Windows Firewall
Set as "Manual" the startup type for:
-HP Network Devices Support
-HP CUE DeviceDiscovery Service
you can right click on the particular service and click on properties....then change the startup type....
this issue will fix for sure....
pls do rate if its found useful...
Apr 02, 2010 | HP Hewlett Packard Pavilion A6200N PC...
IBM ThinkPad T41 Notebook Logo
138 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
