Question about EliteGroup K8T890-A (V1.0A) (MBK8T890A) Motherboard
Pc cannot boot, cannot find SATA HD samsung160JJ
Restart, restart, restart
    President:
  • 2,110 Answers
CHECK THE sata CABLE...IT MIGHT HAVE SOME PROBLEM....
Posted on Jan 28, 2009
Won't boot from SATA Hard Drive
Specs say it comes with a SATA hard drive. Go into the BIOS and check that it is booting to the HD as opposed to the DVD ROM? If it is, then remove the case and check the connections to the hard drive and from the hard drive to the motherboard. If they are all OK, then you need to swap out the hard drive for a new one, or at least get it tested on a system known to work. You may be able to recover data by putting the old HD into a hard disk enclosure.
You can also try booting to your windows media disk and run scandisk to the SATA HD.
Acer Aspire AMD A6 500GB HDD 4GB DDR3 Desktop PC
Nov 11, 2015 | Acer Recertified - Aspire X AX1470-UR308...
Working on a Dell 530 Desktop, installed a new WD 500gb Sata Hd and after setting up Boot in cmos cant get by following Boot to CD Boot Device not installed enter ready to continue. Need Help OS CD in in...
Go back into the Dell CMOS and try reseting all settings back to default. Restart and when it starts to boot, start tapping F12 to get to the boot menu. Try booting to the CD drive now.
***Please rate if this helps you or ask more detailed questions for more help. Thanks
Dec 15, 2010 | Dell Computers & Internet
Sata hdd recognized intermittenly and installation sometimes sata hdd detected and sometimes lost halfway
Hello
Try disconnecting the hd from the motherboard,then reboot.
Shut down all power to pc unplug from wall,then reconnect hd,restart pc.
Be sure that in the bios settings your hd is set for autodetection,if there is a sata option just use auto.
Nov 29, 2010 | AMD MB TUL | AX480A-GF XPRESS200P RT...
Can't boot my Dell Optiplex GX280 from the
Hi there
hey if you boot into bios and you need to make sure that the computer will recognize the hard drive and that the jumper that is on the hard drive is set as either master or slave depending on what you want than make sure that of the parameters are right and apply it. than restart the computer and than see if the cd will now boot and you should be able to continue from here ok
best regards mike
Mar 07, 2009 | Dell OptiPlex GX280 PC Desktop
Selecting Boot Device
If you want to boot from the IDE HD drive then you should get into BIOS and set it as the first boot device, followed by your SATA drive and CD drive. That should do the trick.
Hope this helps,
Sai.
Feb 03, 2009 | Intel D945GCCR Motherboard
Boot up issues will not boot up from HD
IDE and SATA do not mix unless setup properly.
I would use the SATA one as main hard drive and set the other up as an external one on USB
Try resetting the BIOS to boot from CD
on ter lower part of boot screen will tel you the key to press to access the BIOS setup
Usually one of these keys
F2 CTRL+ESC or DEL
when in BIOS check and set to boot from CD
Nov 07, 2008 | PC Chips PCChips A13G+ v3.0 Motherboard -...
Formating HD
Download " Hirens Boot CD " it has a lot of partitioning tools on it try one to check and set hard drive into partitions
Aug 18, 2008 | ASUS K8S-MX Motherboard
Sata vs ide
install the SATA drive in first and install your XP operating system on that one.
Then after thats all set up and running install the PATA drive.
Please let me know how you make out
thanks,
Dec 26, 2007 | Computers & Internet
Asus K8V SE Delux
Try to see in the bios, which is the boot sequence. It could be IDE first and SATA second.
Change the SATA to first.
Or see any option that talks about the boot sequence.
Nov 10, 2007 | Computers & Internet
EliteGroup K8T890-A (V1.0A) (MBK8T890A) Motherboard Logo
85 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
