Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Freezer to cold refrigerator not cold enough
I noticed that freezer is getting frost buildup on the back, when you turn the temperature to a lower setting then no cold air blows into the frig,freezer side to cold frig side not cold, what could be the problem, where are condenser coils on the frig, can't find them to vaccum
Sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Posted on Jan 28, 2009
Bottom freezer door causing ice buildup
If the refrigerator is not defrosting the defrost heater assembly might be burned out. Several times a day the defrost heater assembly turns on for a few minutes to melt away any frost that may have accumulated on the freezer or refrigerator evaporator coils. If it fails, frost will build up on the coils and eventually no air will be able to travel through the coils to provide cooling. The defrost heater can be checked for continuity. If it doesn't have continuity it should be replaced.
Next chance is the defrost thermostat might be defective. This signals that the coils are cold enough. If the coils are cold enough the defrost heater will turn on. If the thermostat is defective it may not be able to sense the temperature of the coils and then won't turn on the defrost heater and create the same problem you mentioned. It can be tested for continuity when it reaches the low temperature of its operating range.
You may also have a bad main control board that tells everything to work when it is supposed to such as telling the defrost heaters to activate or interpret the thermostat message that it is time to defrost.
Jun 12, 2014 | GE Profile Bottom-Freezer Refrigerator...
I have a GE Refrigerator TFX26KPDAAA and the refrigerator part will not stay cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 26, 2012 | Refrigerators
Frigidaire refrigerator/freezer side by side--compressor keeps running
Most problems with side by sides frosting up is due to failure of the defrost heater in the bottom of the freezer section behind the panel inside.
Jun 16, 2012 | Refrigerators
Frost Buildup in Frost Free unit.
You will have to check the defrost timer to make sure it is turning if it is working properly and you are getting power to the defrost heating element below the freezer coil it should get hot if you have a 115volts or so to the element and it does not get hot then you have a bad element
Jun 10, 2010 | Kenmore 57029 Side by Side Refrigerator
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Side by side Sub Zero not cold enough.
How old is "OLDER" ? If there is no frost buildup on the back wall of the freezer you could have one of two problems. On older units the compressor wears out with years of service and no longer pumps efficiently. Or it could possibly be low on refrigerant charge. ether one of these two problems is a sign that is time to update to new unit.
If you have frost buildup on the back wall of the freezer section you then would have a problem in the defrost circuit attributed to the timer, defrost heaters or defrost thermostat.
Jun 11, 2008 | Refrigerators
THE REFRIGERATOR AND THE FREEZER HAVE QUIT COOLING. HOWEVER THE FAN AND THE LIGHT IS WORKING. WHAT CAN I CHECK
Check the back wall of the freezer compartment for snow or frost buildup. Fan running would indicate that the temperature of the coil which cools is cold. If you find a frost buildup on the back wall you more than likely have a problem in the system defrost circuit. You need a service tech.
Apr 28, 2008 | Refrigerators
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
663 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
