Question about Brother MFC-3220C Plain Paper Inkjet Fax
Wont shut down
I tried to copy a document. No copy came out. I tried to shut it down. Now it just says "Shutting down after copy job complete". Cannot shut it off, cannot change to fax mode. When I left it unplugged overnight, the same message came back on as soon as I pluged it in.
  • Doug Winebrenner Aug 02, 2007
    Didn't make my self clear. Paper is not stuck. It didn't copy at all. Basically nothing happened. No matter what button I push or if I unplug it the only thing that happens is it telle me shutting down after jobs complete.
    Correct. Nothing printed from the copy job.
  • 100 Answers
Well, if STOP/EXIT does not work, and niether the Cancel Document in windows, then you'd maybe have to get the paper out by yourself. unplug your printer, adn then open up where the paper goes out, now slightly push it towards you, and then plug it in, and keep doing the pushing. Tell me if it works. remember to do it not in a hard way, just soft. Good luck.
Posted on Aug 02, 2007
  • Morad Muslemany
    Morad Muslemany Aug 02, 2007
    So, it does not print, you mean? the job is stuck?
    President:
  • 1,114 Answers
The only thing I can find in the manual (link below) is to press "STOP/EXIT" to cancel the job. http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000013/FaxMFCBase_UsEngUsr.pdf There is a help page on the Brother site below: http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/colormfc/mfc3220c_us.html?reg=us&c=us&lang=en&prod=mfc3220c_us
Posted on Jul 27, 2007
Scan bizhub 751
have a tech come out service mode and clear memory
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 16, 2014 | Konica Minolta Office Equipment & Supplies
Not able to print, keep saying 1 document on pending. I have deleted everything and still no able to print. scanner, copier and fax is working normally.
Your document is stuck in the printer queue. Usually you can fix this by shutting down the printer completely and disconnecting the power connection then starting over. Depending upon your computer and the software you are using it may be possible to have the computer empty the queue
Aug 22, 2013 | Brother MFC-7860DW Duplex Wireless Laser...
The computer when you turn iot on it wont go to window s it says sum about a disk error
It might be that you have an operating system error. This is usually the result of not properly shutting down your computer. Some of the booting files are damaged or it needs reinstallation of new ones. Try install fresh windows copy to another drive to at least save some of your important files and documents. If the problems persist, eventho you installed fresh copy of windows, it might be that your harddisk has a problem. It might contain some bad sectors or bad blocks. In this case you better consult a qualified and competent technician to properly diagnose the problem and save some of your important documents. My best advise is to go to the brand service center for check up, if it is under warranty (within 1 year from purchase) then you will pay nothing. I just hope my info could help u.
Feb 01, 2011 | HP Compaq 6910p Notebook PC PC Notebook
HP Laserjet M1522nf memory error how do i clear it up
Mem. low 1 copy. Press OK The product completed making one copy. The remaining copies have been canceled because of low memory. Press Cancel to clear the error. Break the job into smaller jobs that contain fewer pages. Memory is low Try again later The product does not have enough memory to start a new job. Wait until the current job is finished before starting a new job. Memory is low. Press OK The product memory has been almost completely filled. Allow the product to finish the job, or press Setup to cancel the job. Memory low Only 1 copy made The product does not have enough memory to complete the collated copy job. Break the job into smaller jobs that contain fewer pages.
GO TO THIS LINK FOR MORE INFORMATION
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=ca&taskId=110&prodSeriesId=3442750&prodTypeId=18972&prodSeriesId=3442750&objectID=c01312064
PLEASE ARTE MY SERVICE
Nov 19, 2010 | HP LaserJet M1522nf Multifunction Printer...
Why my laptop is shutting down? it's getting very hot and his shutting down
Poor cooler under heavy cpu and or graphics job.
Try using laptop cooler.
The cooling system may have a probhlem. Try to go a service.
Aug 23, 2010 | Acer Aspire 5735 Notebook
When a document is copied the copy document comes out larger than the original, but the settings for reduce and enlarge is set at 100%.
sometimes the setting stays in the memory. Try shutting off the copier completely, let it rest for 3 seconds and then try again clear all buttons.
Aug 04, 2010 | Xerox 6180MFP/D Printer
When i shut it down it wont completly shut off it just keeps saying shutting down
Try this To end processes automatically at shutdown -
1. Open Regedit and navigate to HK_Users\.Default\Control Panel\Desktop
2. Double-click on AutoEndTasks
3. Change the value from 0 to 1
4. Reboot your machine
Now hung processes will end automatically when you try to shutdown or reboot your machine.
Regards
Vikas Agrawal
MCA
Jan 18, 2010 | Acer Aspire 4530-5889 Notebook PC
I installed nero 8 on my xp pc as a trial, i uninstalled the program via add/remove programs - the problem i have now is my pc wont shut down completely and wont reboot, when rebooting or shutting down it...
Hi PC;
try booting up in safe mode then shutdown from there, see if you still hang on the blank blue screen.
to go to safe mode, tap F8 when your pc is booting up.
get back to me for feedback. :)
Jun 23, 2008 | Computers & Internet
Printed an alingment test and a copy keeps on printing before I print off any work that I am trying to print
First, try shutting down your computer and restarting. This should clear the print queue, which might have become "confused". You can also turn off the printer to eliminate any stray print job that might be remaining in it's memory.
Jun 10, 2008 | HP Computers & Internet
Brother MFC-3220C Plain Paper Inkjet Fax Logo
55 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
