My frigidaire electric oven's door will not unlock. We were trying to set the self clean mode, it beeped door and then it was supposed to beep lock but lock never beeped. We cancelled the self clean and the vent was blowing air out, after 3 hours, we dis-abled the power to the oven. We tried turning off the power to try and re-set the oven but that didn't work. We can't set self clean because it keeps beeping door and will not show Lock (even though the door is locked). Please help.
If you unplug the range and remove the lower rear cover on your left side you should see the motor with 2 switch's on it. There are 3 possibilitys with it. One of the switch's on the assembly is not working or the light switch for the door is not good. You also can disconect the lead to the motor and connect a power cord to it and that will unlock the door so you can check the dor switch also. if you do not feel comfortable powering up the lock motor then you should call a repair man. But one of the switches is not letting the computer know the dor is locked.
my oven will not unlock now that cleaning cycle is over
What about if it is a wall oven, what do I need to do then?
Door never locks. Just beeps and shuts off
