Question about Lincoln Conveyor Oven - 1133-000-A
Oven will not heat past 300 degrees
When turning on every thing seems to work. but temp will peak around 300. i had two blodgett deck ovens (full size) and replaced one. i am not sure if this is a gas flow problem or if it is something else entirerly or both. any ideas
  • Mark Egan May 11, 2010
    If the gas is cycling and the unit is not reaching temperature, I would be suspect of the thermostat, over temp sensor, or vent system (causing over temperature sensor to kick out).
    Is thermostat rated for >300 degrees, and the temperature you are wanting?
  • 4 Answers
300 far. or cels if its celcius its to high they should run at about 260 or the high temp sensor will shut it down how fast is your belt running it should be 6.30 to 7.00
Posted on Apr 27, 2009
How do I get my Blodgett 911P hotter than the 500 degree mark? 600-750 degrees..
The oven has a max temp of 650° if you aren't getting there with the tstat cranked all the way up most likely you don't have enough gas pressure to reach the temp. Or the air shutters are mis adjusted. Gas pressures should be adjusted by a professional technician or contractor with a meter for testing gas pressures. I've included the link to the manual so you can find general information about the oven.
Mar 30, 2016 | Blodgett Ovens
Blodget zephaire G takes 2 hours to reach temp.
It hard to tell, please let me know what did you see and hear when turn on oven...
Jan 14, 2014 | Blodgett (ZEPHAIREG-DOUB) Double Oven
Whirlpool super capacity 465
Seems the thermostat is malfunctioning...thus when baking at 500..thats quite keeps getting hotter past that point to where the oven thinks its in self cleaning mode. Also seems like the problem because when it cools down your allowed to use it again. There is no way to test it with an ohmmeter. Just remove and replace.
Nov 30, 2013 | Ovens
Pizza scorching on bottom
This may sound simple but....Do you know for sure the oven temp is 550 (use a thermometer on the stone to be sure) The thermostat may be set at 550 but could be running hotter? I have had this problem in the past with ovens.
Mar 29, 2012 | Blodgett 911-DOUBLE Gas Oven
GE Oven is not heating to full temperature.. Also heating up real slow
Thank you for contacting
First you need to check whether you are getting full 220 volts + to the oven. Some oven controls have adjustable knobs where can be fine tuned. The temperature can be calibrated by 25 degrees but not any 200 degrees. I think these can get you may be up to 75 degrees max. It seems like your sensing bulb is mounted right your oven control which has the sensing bulb attached could very well be shot. Also check if the elements work? Does the broil get red when set on broil; does the bake get red when set on bake? If yes the wiring should be ok and possibly/probably is a bad oven temp control. If the elements do not get red, that would have to be investigated (burnt wire, bad selector switch, bad oven control, burnt wire. Turn on the oven with the meter connected. It should show full voltage when you first turn it on and the thermostat will turn it on and off.
If the sensor inside the ovens baking compartment is not damaged, touching any metal part, bent, pitted, no foil is used on the racks or lower plate, in an attempt to keep ovens internal clean, etc, then temp sensor is likely defective. Which means the ECR (control unit) will need to be replaced.
Please get back to us if you have any further query.
Have a nice day.
Nov 13, 2010 | Ovens
Ovens wont heat to temp
The reason to this problem can be due to the faulty
Sep 02, 2009 | Lincoln Conveyor Oven - 1133-000-A
Oven probs
I think you are having a problem with a high limit switch that has become faulty. If you are running this around 400 degrees F. These things fail over time and since you said its a blodgett deck oven I assume it has to be over 10 years old. If you need further help please comment me back.
Hope this helps ya
Jun 22, 2008 | Blodgett Ovens
Power outage Blodgett Conveyor Oven
On the back of the motors there are safty overload reset's, these are small red push in buttons. Also there are fuses for each motor inside the control panels assembly.
Jun 02, 2008 | Blodgett Ovens
Lincoln Conveyor Oven - 1133-000-A Logo
355 people viewed this question
Top Lincoln Ovens Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
