Question about Sanyo DVW-5000 DVD Player/VCR
Won't turn on/red key shaped light on
I've had my dvd player for quite a while, and Sunday while watching a dvd, my player just stopped in the middle of the movie. I pressed the eject button to start the movie back over and the disc door wouldn't shut. So I lightly pushed on the door and it closed. I ended up frustrated went to turn off the player and it would not turn off. So I unplugged it and plugged it back in and now a red key shaped light shows up above the time area and the player will not turn on. Is this machine a mechanical paperweight or can someone help me?? Thank you!!
  • 2 more comments
  • kris ball Jul 26, 2007
    Never mind. I unplugged it for an hour and all is well again.
  • grand1 Nov 20, 2007
    What do you do if you don't have the original remote, my universal one does not have a lock button.
  • pcmale Feb 22, 2008
    yes i have a same problem it shows a red key light (ibeliev that is a child lock) now i have no remote tried a few universal remotes but no luck, none of them have a lock key.
    how do i unlock front penal?
  • Lindsey Luhmann
    Lindsey Luhmann Jun 17, 2016
    What If there's no unlock button? And I might add ours is doing this but we had a bad storm and possible lightning strike
Just in case that happens again...you had the front panel locked out and need the remote to do anything, to lock and un-lock it you press the "lock" button on the remote
Posted on Nov 02, 2007
My Philips GoGear MP3 won't turn on. Is there any way it can get fixed? I've tried resetting it but nothing happens.
(I "ASSUME" you charged it, or tried to). HOW OLD is your MP3 player??
If it's pushing 2yrs old, or played/used on a fairly regular/daily basis,
.....YOU MAY JUST NEED A NEW BATTERY.
Carefully peel up the UPC code strip on back of player. (There is a tiny screw underneath it)
Carefully remove screw. (The snap notches are 'L' shaped inside the edges of the case).
Gently slide/pry open the backside of the case, taking care NOT to break the snap notches.
Open case, REMOVE BATTERY. FIND/MATCH BATTERY TYPE. (look in WATCH batteries).
Place the new battery in player. Close case, restart/turn on player.
Nov 04, 2011 | Philips GOGEAR SA6045 MP3 Player
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
I have a philips remote control and I need the code to control a pioneer DVD player
Though all remotes are differnet just try this it can be kind of standard. But not all remotes are always compatible
1. On the remote control, press DVD once and Turn DVD player off
2. Press and hold SET until the red light blinks twice, then release SET.
3. Aim the remote control at the TV and press SCAN. The red light will blink twice.
4. Continue aiming the remote control and click on and off at the DVD Player (which may take up to 5 minutes) until it turns off. Immediately press any key except VOL-, SCAN, or SET. If SCAN is pressed again after any key stops Auto Scan, the remote will continue Auto Scan of the next ID from where it stopped. If you have passed by the code that turns off the TV, press VOL- one or more times until the TV turns on again.
5. To lock in the code and exit Auto Scan, press and release SET the red light will blink twice.
1. Or if you have a code. Press Set
2. Wait for blinks
3. Put in code.
4. Test it and if it works click set if not try next one.
Jul 17, 2011 | Philips Televison & Video
My Toshiba BDX 2500ku won't turn on...Ive used it before...now it won't even open...please help....its only about 4 months old and we've only watched about 2 movies....
check the back of the player to see if the power cord has come loose, some units have a removable cord and it can get pulled.
Jun 20, 2011 | Toshiba BDX2000 Blu-Ray Player
I have a Sony BDP S370 and I would like to make it region free for my DVDs.
hi,
u can make your dvd for region free DVD play back. but for that you have to purchase an universal remote (ONE FOR ALL URC-7950). through this remote only you can make player DVD region free.
first of all u have to set( program) the remote for the same purpose.
Full procedure for the OneForAll URC-7950 remote is as follows:(preparing remote)
1. Press DVD
2. Hold the magic button until the Power key flashes twice.
3. Press 0533
4. Hold the magic button until the red led flashes twice.
5. Press 994
6. Press Magic key (don't hold)
7. Press 00189
8. Press 1 ( this sets it to key 1 - it flashes twice, if not repeat steps 4 to 8 )
9. Hold the magic button until the red led flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until the red led flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until the red led flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until the red led flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDP-S370 region free
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the OneForAll URC-7950 remote. The power light will start flashing. (blue middle light)
3. Put the player back into standby with the Sony remote.
4. Next time you turn on the player it will be region free for DVD playback.
OK
Jan 13, 2011 | Sony BDPS370 BluRay Player
Unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Jan 03, 2009 | Sony DVP-NS300 DVD Player
O/D off light flashing
I am a retired Ford technician, so I have seen and know why the OD light is flashing, it indicates a problem with the transmission, it is no related to the DVD player in any way, have a parts store like Kragen or others run a scanner on the Van, there will be a trouble code stored that will give an idea of the problem with the van's transmission, post the code back on this thread and I will look at it and give you some idea of the problem and cost to fix it.
Oct 08, 2008 | 2003 Ford Windstar
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
DVD player froze, now only turns off
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Jan 13, 2007 | Philips DVP642 DVD Player
Sanyo DVW-5000 DVD Player/VCR Logo
298 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
