Question about Acer Aspire 3000 Notebook
Boot sector I have windows vista on my acer aspire 3000 laptop and i'm trying to change it back to windows xp but every time i try to put the recovery cd in it starts then just goes back to like i'm starting the computer. cd's won't boot.
  • 107 Answers
Go 2 bios set up make your cd rom b the first bottable device.
Posted on Jan 28, 2009
Acer aspire 5100 stops at agpcpq.sys and keeps rebooting. Will not boot up normally, safe mode, or any other way. Booted off of install CD and ran chkdsk /r. No luck.
Boot from the CD again and this time run chkdsk /f
This command will try to fix any errors with the file system and check for and recover bad sectors.
Hope this helps.
Aug 28, 2009 | Acer Aspire 5100 Notebook
Won't boot past Windows XP main screen. Windows XP may have a corrupt file. How do I correct without full recovery?
Try starting in Safe Mode and check if you can start it? In case it starts in Safe Mode, you may do the system restore to the date it was working fine.
Aug 11, 2009 | Acer Aspire 3000 Notebook
How to restore my acer aspire 5001 to factory settings i tried the normal restore but it dont work can you help pls ,,cheers neil
Hi I contacted Acer about this myself and this is what they wrote back.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jul 09, 2009 | Acer Aspire 5100 Notebook
I want to take my acer 3690 back to when i bought it
There is no way to roll back from Vista to XP. If you still have an XP CD Key you can re-install using a windows disk of the same type using your code. All the drivers should be downloaded first to a CD from the manufacturers web site. Plus any data you would like to keep.
May 13, 2009 | Acer Aspire 3690-2196 Notebook
Cant install windows xp
You Need To Boot From The XP CDrom...
Press Power Button To Boot, Hold Down F-12, Choose To Boot From CDROM, Go Through The Windows Setup Process, Remove Vista (delete it), then Format and Install XP...
Your 7520 can use the drivers from another acer model, for instance, try aspire 3000, or 5000 drivers.. or try another model...
If it's not the correct one, it will not install and throw up an error telling you it is incompatable and not going to install....
Feb 05, 2009 | Acer Aspire 7520-5757 Notebook
Back to get the original vista version
Well, with any amount of luck, when you installed xp you didn't erase the recovery partition. Just boot into the recovery partition. Some laptops will let you have that option on a regular boot.
Of course, if you have the vista cd, just boot with that. You can download a free vista recovery cd here:
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
If that doesn't work, try to download easyBCD and hope that your vista partition shows up in xp:
http://neosmart.net/dl.php?id=1
Feb 02, 2009 | Acer Aspire 4720 Notebook
Boot problem on Acer Extensa 4220
do a fresh installation of operating system or if your laptop provides recovery then you can also do that. may be your problem is due to system files.
Jun 28, 2008 | Acer Aspire 3000 Notebook
Won't boot
You need recovery Disc Or Windows Vista disc. Else you need Windows Xp With sata driver in It. Please try to find out from your friends Or from Acer Service center may be they will Help u.
Mar 12, 2008 | HP Pavilion dv6000z Notebook
Acer 3000 not loading
Hey,
firts put the original harddrives back in place :)
then you need to enter the 3000's bios If I remember right
thats done by pressing f2 or del in a acer. it should tell you what button is correct on the bootup screen.
Then you need to change the boot order to haveing the dvd/cd drive before the harddrive, since right now its booting strate from the harddrive.
Then you should be able to restore the operateing system with the disks that came with the laptop and or from a normal xp or vista cd/dvd.
good luck!
Feb 14, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
120 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
