Question about NEC MultiSync GT950 Multimedia Projector
Blue Smudges On Screen
I keep getting large Blue Smudges on the left side of the screen more so if its a dark image. I have got a new lamp and the problem is still there. All the filters are clean do i need to clean the colour lenses and if so how do i go about getting to them?
  • davidbrum482 Jan 29, 2009
    Thanks Mate
    I will look into this thanks for your time
    Dave
    President:
  • 1,073 Answers
I sugest you use compressed air and blow carefull in the projector.
Take out the new lamp and remove the topshell before using the copressed air. If that dosent help i recomend you to let a pro clean the lenses inside. Its not that easy to do that yourself, they are quite smal and fragile and its very easy to damage them if you doing it wrong.
Good luck to you M8
Nic
Here is the manual if that helps you
http://www.support.nec-display.com/dl_service/data/manual/english/gt950_manual_e.pdf
Posted on Jan 28, 2009
  • 1,031 Answers
You need to clean the mirrors inside your projector, you can either open the shell and use compressed air,to clean it
If you are going use compressed air, make sure you dont ever hold it near the mirrors.but you can can also give to a professional to clean if you cant clean it Its cheap to clean a projector by a pro, it takes a pro about 10-15 minits to do it.
  • Starnley Johnwells
    Starnley Johnwells Jan 28, 2009
    if after cleaning and the problem still persists then You probably have a polarizer failing on one of the LCD panels inside.
    There are 3 of these in LCD projectors, red, green, and blue. They all
    get the light fed into them, that light is then combined and fed
    through the projection lens.
    Brigadier General:
  • 3,614 Answers
Related problem needs the unit clean once you have a "dust blobs"
  • micromaster
    micromaster Jan 28, 2009
    this few steps gives you an idea on How to clean the unit;
    1. Underside of the projector. you can find the filter under the hatch on the left side, lamp is under the hatch on the right rear.de of the projector.
    2. Filter hatch opened and fan bracket removed. Filter is gray foam in lower left. Clean the filter with canned air or wash and dry thouroughly before replacing.
    3. Clean the projecter using a canned air.
    4. Hold the unit vertically to avoid any liquid get inside of the parts
    5. On the LCD and polarizer area. You've got to blow out all the crevices in this area, using care not to scratch or dislocate anything.
    All done!
  • NEC Master
  • 19,396 Answers
More then cleaning the lenses , you will need to reassemble them, or replace them.
Looks like the lens assembly is out of place or damaged, the lens assemby should be taken apart and re-mounted.
Call the phone number listed on the owner manual to get a replacement lens instead.
I just replaced bulb with new and after a day there is a dark spot on the screen
I have the same TV - I have a dark spot in the upper left hand corner. I have always thought this TV was dark. Be sure to get OME lamp. Cheaper ones are not worth it and can damage your TV more.
dlplampsource,com--Just a note if this ever happens to you. TV would not come on in the AM-Had no picture, but had sound. It was not the lamp, but the safety switch. It's blue and at the bottom of the lamp housing. As soon as I flipped it and replaced the back cover, the TV came on.
Dec 22, 2012 | RCA Scenium HDLP61W151 61 in. HD-Ready...
We purchased a sony wega hd lcd projection tv. The set had a great picture until the lamp had to be replaced. The screen got progressively darker until the screen went completely dark. After the lamp...
It sounds to me like you got a fingerprint on the lamp when you installed it. The oils in your skin can cause all kinds of problems on a lamp that gets soo hot. I recommend replacing the lamp again and using a tissue or sterile glove to hadle the new bulb. Also, before replacing the lamp make sure to clean and vacuum out the light engine box and fan.
If the problem persists, then the LCD panels inside the light engine have been heat damaged. There is a class action lawsuit in New York that is trying to extend the light engine warrantee on Wega TVs. You should give Sony a call at 1-800-222-SONY for information and more assistance.
good luck!
Dec 03, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Dull laptop screen back light
You may have a faulty CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Dec 30, 2009 | Dell Latitude C610 Notebook
Dark spot issue.
Its an acrylic condensing lens inside the light engine that has melted/warped. You have to pullout the entire light engine then disassemble the optical light tunnel to get too the lens. Then you need a lens-smith to cut a new lens because Infocus won't stand behind this design flaw. Its really a shame on Infocus!
If you need more info contact us here: click here
Sep 19, 2009 | InFocus ScreenPlay 61" Rear Projection...
Have two dark smudges on screen
Dear Chaplink,
You said "two dark smudges on monitor screen".
Asumming that these smudges are digital and not just something tata you can remove with cleaner, If your moniter is back-projecting then the issue is probably that the projector has been damaged.
If your monitor is a flat-screen then the gels inside of it are misplaced from somone touching and damaging your screen.
So basically, the only practical thing you can do is buy a new monitor.
If i have been helpful, then please give me a positive rating.
Jul 04, 2009 | NEC MultiSync LCD2170NX-BK - flat panel...
Dark area on left side of screen of Dell Inspiron 1525
ok , i have had this problem on bolth my dell inspiron laptops , on a 6400 and a 1525 . the 6400 had the lower left corner all dark and the 1525 was split right down the center . i fix bolth of em in a really simple way , turn on ur pc and go into windows , press the blue Fn button and the down arrow untill ur brightness from ur backlight is completely down . keep it that way with the screen on with a screen saver for about one hour then turn brightness back up but not all the way up cuz in my case the problem hapened again , but when i keep it just one click darker , boom problem fixed . from what i can figuere out is that the inverter aint powerfull enought to power the backlight and tends to over heat , so keeping the backlight a bit lower tend the keep em ok
May 28, 2009 | Dell Inspiron 1525 Notebook
Blue patch on screen KDF-42WE655
This is problem of Optic Block (light-engine) that will be replaced and it is costly fix.
Click HERE to get price info and part image.
May 07, 2009 | Sony KDF-42WE655 Television
Gestetner 2722z copier, new drum, new transfer belt, smudges yet
The image is not transferring properly..........
remove and clean all corona wires (thin wires that create the latent image) use a q tip and dip in rubbing alcoholhot
Also make sure the fuser rollers are hot(insert or trick safety switches to determine if the fuser lamps are lighting usually upper and lower
Also check the imaging lamp to be sure it does not have any dark burn marks on it and clean the mirrors and the glass under the coy area
Dec 30, 2008 | Gestetner Office Equipment & Supplies
Optoma HD72 displays white circles when the picture is dark
Have your projector professionally cleaned. It is dust in the inside optics. You should not attempt unless you are very skilled. if you are going to do this yourself have a lot of compressed air on hand.
Aug 25, 2008 | Optoma HD72 Multimedia Projector
NEC MultiSync GT950 Multimedia Projector Logo
75 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
