Washing machine won't spin
Hotpoint Aquarius Extra WMA36 : The machine appears to wash but when it reaches the rinse and spin it just fills up and empties without spinning.Tried to put it on spin only - nothing just the sound of the pump.Before it stopped working I noticed a buzzing/vibrating type noise when it was spinning.
  • 1 more comment
  • David Keysell Jan 28, 2009
    The model number is correct.
    It was one of the two bushes on the motor worn.
  • Mark Egan May 11, 2010
    Please confirm you've given the correct model number.
    President:
  • 1,214 Answers
This site should help -
http://www.washerhelp.co.uk/diy-repair-help_4.html#cl_q2
I am thinking moor brushes, but it could be any one of 3-4 different problems.
Posted on Jan 28, 2009
  • Mark Egan Jan 28, 2009
    Sounds like a FixYa to me considering where you started from. :-)
    Thanks!!!
Hotpoint Electronic 800 WM 12 Aquarius won't rinse
If it won't rinse because it won't fill, it's most probably because the cold water inlet valve is faulty. Many machines will only rinse with cold water....No cold water.....No rinse!! Not a big job.....Nomess
Apr 13, 2010 | Washing Machines
Hotpoint washer
common problems with timer which work like a clock and goes though the cycle, bad timer will cause it not to go through its cycle. it very cheap and easy to replace everything is all plug in.
Nov 14, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
HOTPOINT AQUARIUS WMA36
hi, i just wanted to know where the fuse is for a hotpoint washing machine, cheers
Oct 28, 2008 | Hotpoint Aquarius WD63 Front Load...
My hotpoint aquarius extra WMA36 is making a terrible banging noise whilst on final spin. When i open the door to take out the washing there was a smokey mist coming from inside the drum. Are the bearings...
hotpoint had a problem with the early bearings on these, so it would probably be the fault. or you may want to check the security of the concrete weights, one at the top and 1 at the rear of the tub.
Mar 16, 2008 | Washing Machines
Does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Feb 16, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washer will not spin
normally i would suggest changing motor carbons for hotpoint washers, but my experience is that the WMA motor armature is weaker than the carbons, normally if there is no connection fault a replacement motor is the answer 9 times out of 10, not a job for the amature
Aug 28, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
309 people viewed this question
Top Washing Machines Experts
