Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Front-loading washing machine
Washing machine programmes appear to be out of sync suddenly.. I have cleaned the filter and it was pretty choked up.. I wonder if that might have affected the programmes in some way.. water seems not to be coming through with the same force as usual either on certain programmes..
  • ishbel Gray Jul 24, 2007
    Hi Jackboy..Thanks for that!..Checked filler hose and thats ok..but as for water level sensor..now there's a thought!! I will certainly check that out ..if you can tell me where I can find it!!
    Thanks!
    Ishi
  • ishbel Gray Jul 25, 2007
    Thank you!.. Such an interesting and detailed explanation of the function and location of the water-level-sensor! I will away and check this out now!
    Genius:
  • 2,985 Answers
Kink in the filler hose Water level sensor blocked[as you cleaned the filter, did you do this one?]
Posted on Jul 24, 2007
  • Anonymous Jul 24, 2007
    Water level sensor is at the highest point in the machine and looks like a black doughnut
    This has a wire to the harness and a plastic tube that runs down to the lowest part of the drum housing where it is attached to a bottle like device that's is fixed to the housing.
    Water goes into the bottle which compresses the column of air in the tube which actuates the switch which tells the programmer how much water is about.
    This little bottle also get filled with crud- soap residue and will interfere with the water compressing the air column.
    So it too needs a good clean out.
SOURCE:
A light came on to clean the washer. Is there something special I need to do?
Even a blonde can do it! Quick fix/repair for Kenmore He2 ...
? 4:57
https://www.youtube.com/watch?v=4o9hWHQkOMM
Sep 1, 2013 - Uploaded by And Justice For All
Quick fix/repair for Kenmore He2 front loading washing machine... a Kenmore He2 front loading washing machine when blinkinglights error code occurs ... How to Clean Front Load WasherDrain Filter and Empty the Water ...
Front Load Washer Pump Clean Out - YouTube
? 3:03
https://www.youtube.com/watch?v=f9uS8_0-pWY
Sep 6, 2012 - Uploaded by GE Appliances
If you have a front load washer with a pump filter, your pump filter may become ... pressed start again but it still stops and the cleanpump light still comes back on. .... Samsung Washing Machine cleaning the pump & coin trap
Nov 29, 2015 | Kenmore Washing Machines
What may be causing my washing not to finish the washing cycle
If you think your washing machine may be faulty, check the following points before calling a Service Engineer. These checks could prevent a charge being made for the Service man's visit if the machine is found to be in perfect working order.
Initially check the filter on your washing machine and clean if necessary, your manual should detail this procedure.
If your machine will not start or complete the programme, check:
  • The plug, the socket and the switch, if necessary, with another appliance.
  • The fuse in the plug.
  • That the door is closed.
  • That a programme is accurately selected.
If water will not enter, check:
  • The hot and cold hoses are correctly connected to the relevant caps and that these are turned on.
  • That a suitable programme has been selected.
If water will not drain, check:
  • That the outlet hose is not kinked or raised more than 40
Oct 22, 2014 | Zanussi FS1455W Front Load Washer
My washing machine is not draining at all however it is washing
DOES THE PUMP MOTOR WORKING OR NOT ?
DO YOU HAVE CLEAN THE FILTER ?
MAYBE SOMETHING IS ON FILTER THAT DOES NOT LEAVE THE PUMP TO RETURN (PAPER COLOR- COINS ECT)
OPEN THE DOOR IN FRONT TO OPEN THE FILTER TO SEE IF HAS SOMETHING . BE CAREFULL THE WATER HAS INSIDE WILL COME OUT . IF HAS A HOSE FOR DRAIN OPEN IT TO EMEPTY ALL WATER BEFORE YOU OPEN THE FILTER
. AFTER PUT THE PROGRAMME FOR DRAINING TO SEE IF THE PUMP ROTATES THE PROPELLER .
Oct 18, 2013 | Zanussi WJS1397W Front Load Washer / Dryer
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
What is problem code IE and how do I fix it on my LG front load washing machine?
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. if this doesn't help then there are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg
Hope this helps.
Mar 09, 2011 | LG WM-2277HW Front Load Washer
Not spinning and emptying
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Zanussi FJD1266W Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
