Question about GE 36 in. Monogram ZEU769 Electric Cooktop
How to remove burnt grease, fix lightly scratched black stovetop?
I am trying to remove a very recent Burnt Grease from my Black stove top. While trying using Lysol Cleaner, Windex, Soap & Water and a scratch pad that is not very abrasive, I dulled and lightly scratched part of the area where the burnt grease is on. What effective products can I use to remove the burnt grease, and repolish the area with the lightly dulled sctatched surface?
  • 257 Answers
Hi, I assume we are talking about a flat glass top. First the bad news. using any abrasives will permanently scratch the glass hence the dull spot. You can however make it look a little better. Grease spots and the like can be removed with a flat razor blade scraper which needs to be held flat to avoid the corners making scratches. Use any good glass/ceramic cooktop cleaner ( which is the ONLY cleaner you should ever use ) (available in your local grocery diy store and some hardware stores). The cleaner is a thick liquid, put about a dime size drop on each burner area and use a paper towel to buff out the finish like waxing a car. Once it looks clean flip your paper towel over and shine the top to like new. Good Luck!
Posted on Jan 28, 2009
  • Jim London
    Jim London Feb 04, 2009
    Hi, I hope I solved your problem, Please rate my response, your favorable ratings help others that may have the same or similar problem. Thank you!
I've burnt enamel on to my Technika glass cook top and would like some advise on how to remove the burnt enamel without scratching the glass cook top.
Posted on Aug 28, 2009
What may cause the oven overheating during self clean
well last time I checked the self clean went to around 600 degrees . has to to burn off the stuff burnt on inside . and YES outside gets really hot .
Aug 28, 2014 | General Electric Ge Stove / Oven / Range...
I have black swirl scratches from using abrasive sponge on front of black oven door
There is this white stuff sold for glass-top stoves. I presume it is good old iron cleaner, a very mild cleaner/polish. Also consider toothpaste.
Dec 01, 2013 | Amana 30" Self Cleaning Electric Range...
What's the best way to clean the Zanussi stovetop? I can't clean the glass stovetop well enough. i don't want to use a scouring pad as i'm afraid i will scratch it but there is burnt coffee, milch, etc...
There is a product called cerama bright (Not sure of the spelling). Specifically formulated for exactly this type of cleaning. Availible through just about anywhere (Home Depot, Lowes, Wallmart, etc) Good luck!
Aug 30, 2010 | Zanussi 23 in. ZKT641H Electric Cooktop
FRONT BURNER HAS NEVER WORKED, HOW CAN I OPEN FLAT TOP AND TRY TO FIX IT?
First, determine if the burner element works by swapping it with a similar sized element on the stove. The eyes pull up and out away from where they go under the deck. If the burner works, the problem is likely with the receptacle, which is located below the deck. Trip your stove breaker, which is located at the panel by your meter. Make sure that the power is off completely. Raise the stovetop (deck) by lifting the front edge of the deck sharply. Some tops have a rod to hold them up; some do not. The receptacle has a screw that holds it to the top, and sometimes a clip. You can check the voltage at the receptacle. If the receptacle has any evidence of chipping, or having been burnt or damaged, it should be replaced. Replacement receptacles can be obtained at Lowes, H/Depot, similar. You'll have to cut the wires on the old one, install the shrink tubing, install the new receptacle, make up the connections, tape them up and apply the shrink tubing supplied. Sounds like a lot, but there relly isn't much to it. It takes longer to tell it than to do it! (Once you've done it a few times!)
Best regards, --W/D--
Aug 08, 2009 | Cooktops
Viking pro 6 burner cooktop igniter won't stop clicking after lighting on two of the burners
Do not attempt if your stovetop is hot, you will get burned!!
This is an easy fix, the problem is your burners aren't lined up properly. Remove the iron grates (what your pots rest on) and the burner cap (the round black top on the burner) and finally the burner base (the round golden colored piece resting on the stainless stovetop). If you flip the base over you will see that it is keyed, meaning there is a grove that fits the indentation on the stove top. When you replace the base make sure to line the grove up with the indentation. If it's not flush with the stove top, slowly twist the round burner base until it falls into place. That's it!
Jul 09, 2009 | Viking Cooktops
Burnt on stains on the inside glass door of my kitchenaid oven
DeBruce Polish should remove those types of problems and also render the surface more "Cleanable". This stuff really works on glass anomalies.
Check out debrucepolish.com.
DEBRUCE METHOD on You Tube
Apr 11, 2009 | KitchenAid 32 in. KECC508 Electric Cooktop
Can't remove burnt milk from right burner on stovetop?
I'm happy to say burnt milk can be removed with a combination of cerama bryte and let sit for one hour and then lots o elbow grease hard rubbling with also applying Mr. Clean Magic Eraser. The Mr. Clean Magic Eraser works very well but you have to still rub alot to get it safely scratch-free removed.
Dec 13, 2008 | Jenn-Air JED8430 Electric Cooktop
Whirlpool Oven, Ceran stove top
I want to say that since I posted my original problem with black spots appearing on the Schott Ceran top, I took pictures of the top and attached them to a complaint sent to Maytag. Approximately 3 days later, a Maytag representative phoned and offered a brand new top-basically stating that there is a fault with the tops. They would not pay for the labor to replace the top. My husband downloaded the instructions from Maytag website and installed it himself. These spots actually appear from within the surface and are not the result of a boil over, etc. The spots on my burner grew to the width of the burner. If you search the internet, you will see many others with the same problem with the Schott Ceran tops. I will never buy another!
Nov 20, 2007 | Cooktops
GE 36 in. Monogram ZEU769 Electric Cooktop Logo
4,014 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
