Question about Raymarine RAYTHEON S2G Notebook
Connecting nmea to s2g
I have not come across the connector on the back of the raymarine course computer (a grey connector with plastic lugs on the top). Please advise how to make connections
Thanks
Neil
2 Suggested Answers
SOURCE: connecting nmea to raymarine s2g course computer
There is tool secreted behind the rear panel that enables connection to the block All working now!!
Posted on Jan 29, 2009
What is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
I'm taking this as you want to send the gps information to your C80 not receive from the C80? If this is the case the brown wire on the garmin is the nmea data out +. The Black wire is considered nmea out neg (-) of the garmin. So hook the garmin brown to the white on the raymarine. Hook the black from the garmin to the green on the raymarine. That means you are outputting lat/long info to the raymarine from the garmin.
Jan 14, 2012 | Raymarine C80 GPS Receiver
Can Raymarine DS500x receive NMEA from GPS 125? How to wire?
Output on GPS should be connected to input on listening device.
Nov 20, 2017 | Raymarine Raystar 125 Gps Sensor
Trying to connect a furuno fcv-585 to a raymarine a-65 via nmea with difficulty !!
Just remember this tip Nmea out + goes to NMEA in + and so on. After that you have to make sure the unit is set up to send those sentences and or receive them. Aside from that it should be pretty easy. However if you hook them up wrong you may blow the port (you won't know that you did it either) No smoke no nothing it just wont pass or receive data.
Nov 27, 2009 | Raymarine NMEA 0183 (E55059)
Can i connect nmea outputs from a raymarine e-80
yes, you need the NMEA out cord set for the E 80 and hook the output of the E series to the input on the power data cord on the Garmin - out to in
Sep 30, 2009 | Garmin GPSMAP-640 GPS Receiver
My plotter seems not to output NMEA to my DSC radio and auto helm
Your plotter can talk to you Radio and your pilot. It sounds like one of two things.You must go into the system setup menu and turn on the nmea sentances. You will need to turn on RMB, RMC, GGl at least. You can turn on all the sentances if you like it does not matter. If this does not fix, check color of wiring is correct. Remember you have to go from NMEA + out (on plotter) to NMEA + IN on Radio.Then you need NMEA - out(on Plotter) to NMEA - IN on Radio.
You can look at the sentances wirth a multi meter coming out of your plotter. You put meter in DCV and connect across the NMEA out lines. You will see the meter move every second or so as it send a sentance.
Jun 09, 2009 | Raymarine Raychart 435 GPS Receiver
Raymarine st8002 wired to furuno
The st8002 is not compatble with rs232 data. You need to supply it with nmea 0183 data. You will need to wire it to the "NMEA port IN" on the pilot to NMEA out on your Furuno and turn on the mnea sentances "out" on your Furuno. You will need to turn on at least the following sentances GGA GLL RMB RMC.Hope that helps.
Apr 20, 2009 | Raymarine St8002 Smartpilot Autopilot...
Installation raymarine st6002
The power cable of your 2106 acts as a data cable also. You should find additional unused wires on the cable. Locate the brown and blue wires. You will need to connect the brown wire to the "NMEA OUT +" terminal on the autopilot course computer and connect the blue wire to the "NMEA IN +" terminal on the course computer. Finally, connect the "NMEA OUT -" and the "NMEA IN -" to ground (preferably the same place that the Garmin is grounded (black wire). Be sure that the Garmin interface is set up for NMEA In / NMEA Out. That should get you going!
Feb 20, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Connecting nmea to raymarine s2g course computer
Jan 28, 2009 | Raymarine RAYTHEON S2G Notebook
I bought a C80 Raymarine Plotter this has a NMEA pigtail with Brown, Screen, Yellow, Green And White wires I haave also bought a RS 125 Receiver this has a pigtail lead with Red , Green, Yellow, Brown and...
If you have a Raymarine pilot it makes sence to wire it all up to Seatalk. Wire as follows Red to red , silver to silver, yellow to yellow, brown(on rs125) to silver on seatalk buss Green (on rs125) to red on seatalk buss.The above is for the conection between RS125 and C80.
To hook the pilot to system you just need to hook the seatalk lines (red, yellow,silver) from the pilot to the conection with the RS125 and the seatalk cable to the C80.(Color for color).The sea talk connection for your pilot can be picked up from you course computer they are labeld and colored on the unit.
If you are not running a course computer as in the case with the older wheel and tiller pilots you will need to take a sea talk cable and cut it. Once it is cut you will see the red yellow and silver wires and you can tap into there . Remember to connect the cable back together were you cut it. Hope this helps
Dec 15, 2008 | Raymarine C80 GPS Receiver
Raymarine rc435
ripoli, This should site should help you now and in the future: http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_alp.php?p_sid=8fkbDBti&p_lva=&p_li=&p_new_search=&p_accessibility=0&p_srch=&p_sort_by=&p_gridsort=&p_row_cnt=696&p_prods=&p_cats=&p_pv=&p_cv=&p_search_type=answers.search_nl&p_nav=foot&p_li=&p_page_head=1&p_page=1&p_page_foot=1 Good Luck, Tim
Feb 05, 2007 | Raymarine NMEA 0183 (E55059)
Raymarine RAYTHEON S2G Notebook Logo
66 people viewed this question
Top Raymarine Computers & Internet Experts
David Payne
David Payne
Are you a Raymarine Computer and Internet Expert? Answer questions, earn points and help others
