Sharp MD - E9000 will not record onto mini disc Error Code 41 showing in display
  • ray_euphoniu Jan 28, 2009
    Back of machine shows "E9000H"
    "Preset W"? - Don't have one!! Presets simply scroll through tracks for CD & MD. Have tried using suggestion but no reset message!
    Further help, gratefully accepted
    President:
  • 2,559 Answers
Recording on a MiniDisc
1. Use a connection cable to connect an external device to the AUX INPUT sockets.
2. Press the ON/STAND-BY button to turn the power on.
3. Press the AUX button.
4. Load a recordable MiniDisc.
5. Press the REC button.
6. Start playback on the external device.
7. Adjust the recording level using the TUNING (X or W) button.
8. Press the A-MARK button on the remote control to activate/deactivate the auto
mark function.
l If you turn on the auto mark function, the unit pauses when a silence lasts for
1 second or more, and creates a track number.
9. Press the MD 06 button.
To stop recording:
Press the MD button.
If that don't work,continue with other options below
MiniDisc
Symptom
A recording cannot be made.
Is the MiniDisc protected against accidental
erasure?
  1. Is the MiniDisc protected against accidental
    erasure?
  2. Did you try to make recording on a playback-only MiniDisc?
  3. Can you see the "DISC FULL" or "TOC FULL" message in the display?
If trouble occurs
When this product is subjected to strong external interference (mechanical shock, excessive static electricity, abnormal supply voltage due to lightning, etc.) or if it is operated incorrectly, it may malfunction.
If such a problem occurs, do the following:
1. Set the unit to the stand-by mode and turn the power on again.
2. If the unit is not restored in step 1, unplug and plug in the unit, and then turn the power on.
Note:
If neither operation above restores the unit, clear all the memory by resetting it.
Clearing all the memory (reset)
1. Press the ON/STAND-BY button to enter the power stand-by mode.
2. Whilst pressing down the PRESET button and the DISPLAY (DEMO) button,
press the ON/STAND-BY button.
After the “RESET” is displayed for about 1 second, the unit will enter the power
stand-by mode.
Caution:
This operation will erase all data stored in memory including clock, timer settings, tuner preset, and CD or MiniDisc program
Note (There are 2 types of mini disk).
Playback-only MiniDisc:
This type of MiniDisc is used for commercially available
prerecorded music. This is the same kind of optical
disc as CDs. Playback is performed using an optical
pickup. (Recording and editing are not possible.)
Recordable MiniDisc:
This is a “raw disc” on which recording can be performed.
A magneto optical disc is used. Recordings
are made using a laser and magnetic field. Repeated
recording is possible
Note
Recordings cannot be made in the following situations.
If you try recording on a playback-only MiniDisc (commercially available music
MiniDisc).
If a MiniDisc is protected against accidental erasure
If there is no more recording space left on the disc
When the "TOC FULL" message appears
If a disc's TOC has been damaged.
Posted on Jan 28, 2009
    President:
  • 2,110 Answers
1 Press the ON/STAND-BY button to enter the power stand-by mode.
2. Whilst pressing down the PRESET W button and the DISPLAY (DEMO) button,
stand-by mode.
    President:
  • 1,214 Answers
Please confirm the model number. E9000 cannot be found on the Sharp website.
  • Mark Egan Jan 28, 2009
    Hmmmm. Is this a mini disk player?
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://www.minidisc.org/repair_q2.html
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
Md sony mz-r50 error blank disc
maybe flat cable recorder lense is too short and now it is broken...
Mar 13, 2013 | Sharp MD-R3 Mini Disc Player
Sharp MD MS 702 shows sound is being recorded but on playback shows blank disc, what could be the problem?
That does not sound good. Being optimistic, though, what happens if you record something and then finalize it? Will it play then?
Will it play a previously recorded MD?
Feb 09, 2013 | Sharp MD-MS702 Personal MiniDisc Player
Display showing C13-disc error, continually
Your deck cannot read the table of contents on the MD, you may have the disc shutter locked, you may have a bad disc, you may need to reformat the disc before it will record or it may be dirty or the deck is not level or the disc is bad (whew), tye another disc...
Mar 08, 2011 | Sony MDS-JE520 Mini Disc Player
When I input a disc and hit play I receive an error which says "TOC ERRORa".
Possible that the disc is not reading and so the the TOC- table of content error must be referred.
It can be due to a poor head tracking or the failure of the data being read or processed.
Clean the head and use a good disc to be checked once again. If so the optical head can be faulty as it might be getting weaker.
Nov 06, 2010 | Sharp MD-MS702 Personal MiniDisc Player
Sony MZ-N505 - says mini disc is blank
Hi- it sounds like the record head is bent or needs adjustment. I do repairs on Sony minidiscs, so you may contact me at: masondixon@netzero.com for help.
Jacques
Nov 03, 2008 | Sony Net MD Walkman MZ-N505
Toc error problem
HEY,
t is not the topic, but I'm for al long time searching for the sharp md-mt20h and I see that you buy a new md player? Were can I buy him?? thanx
Sep 20, 2007 | Sharp MD-MT20 Personal MiniDisc Player
Sharp mini disc md-mt16
Is the Disc inserted UPSIDE DOWN? Turn it over. Are the Lens Dirty? Clean them. Are Your DISC's Dirty Or Damaged? Get one that is Clean And NOT Damaged.
May 21, 2007 | Sharp MD-R3 Mini Disc Player
131 people viewed this question
 Grubhead
Grubhead
