Question about Frigidaire FEF366DC Electric Kitchen Range
Frigidaire ceramic cooktop burner turned on by itself
Its a 2006 professional series - one burner turned on by itself before my eyes and the temperature kept changing, tried to turn it off but was not able until finally unplugged from the wall. What is wrong? This is a potential fire hazard!
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
Fix the eyes on the glass top
Hello jackie wakefield, thank you for your post! Based off the information you have provided you would like to fix the burners located under your Frigidaire range glass top. In order to replace the burner you would need to remove the cooktop. Regrettably this is not a simple DIY job. I would recommend having professional technician come out to your home for proper disassembly of the cooktop and replacement of any electrical components. Hopefully this information is helpful. -Matt
Jan 01, 2015 | Frigidaire Kitchen Ranges
Frigidaire ceramic stovetop burner not working
The switch controlling the burner is just a voltage controlling unit (rheostat). It needs to be replaced
Aug 30, 2014 | Cooktops
Frigidaire Oven surface light stays ''on'' even when cooktop off
I unplugged the stove, un plugged all the burners cleaned them, put them back on plugged the stove back in and the light went out, something to do with unplugging it I think. reset it or something.
May 10, 2010 | Frigidaire FEF326 Electric Kitchen Range
Range Ceramic Cooktop 1 burner not working
I would try replacing switch for that burner. But it also could be a defective burner.
Oct 20, 2017 | KitchenAid Kitchen Ranges
Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Nov 20, 2008 | Frigidaire Cooktops
Burner will not turn off
You'll need to replace the burner switch. This happens when the contacts become fused together.
Mar 24, 2008 | Frigidaire FEF366DC Electric Kitchen Range
Frigidaire glass cooktop
first try putting pans on top and see what they do you should not operate these type of eyes with nothing on them as you will burn out the sensors in the eyes if nothing is there to reflect the heat back to them if it does the same thing with pans on them then you will have to replace the elements
Feb 11, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Frigidaire FEF366DC Electric Kitchen Range Logo
1,100 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
