Question about Toshiba SD R2312 CD-RW/DVD-ROM (Combo) Burner
DVD/CD DRIVE NOT WORKING
MY COMPUTER CAN SEE THE DVD / CD DRIVE
    President:
  • 1,257 Answers
Check the cables if they are connected properly and see if the cd/dvd rom is first detected in bios..
Posted on Jan 28, 2009
My cd drive is not working
Posted on Apr 24, 2009
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
How do i play a dvd and a cd in my compaq presario FS7600?
Put it in the CD Drive - open My computer and left click on it if it doesn't auto-start.
CD Drive may not be working if can't read from My Computer
Apr 04, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
I am not able to install it.The windows is recognising the LG player.
Hey,
Cd and dvd drives are installed automatically on windows when they are connected properly. if your drive is not installing then your computers windows has problems, I would insist that you use recovery cd's to restore the computer to original state or use the windows installation cd to install windows to the computer again.
Note that the cd / dvd drive may work outside of windows, so you may be able to install windows with the drive even though it doesn't work in windows. check bios if the drive is detected there or not.
heres some info on the bios, how to get there and how to use it.
http://www.youtube.com/watch?v=Tc1t3c5Yke8
you may need to change the boot order so that the cd starts before the hard drive.
May 05, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Dell Inspiron 4100 won't play dvd, but will play cd's
You have problem with your cd-drive's lens.
May 20, 2017 | Dell DVD-rom DVD Drive
Cd and dvd do not work
  1. what OS? XP? if yes, is SP3 installed? XP has big troubles with dc/dvd or BRD drives. so, say what OS first.
  2. driver must match OS, so....
  3. what media are you attempting to read, CD, DVD, Blueray
  4. is said media, (real) or is it record-able , like CD-r or DVD-R
  5. we have idea what you have there , only a620 old.
May 06, 2017 | HP (176135-630) (176135630) Internal 48x...
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Dvd combo
Did you try axcessing the drive manually ??? Start > My computer > D:(you cd drive),, If it doesnt show up then the drive may be damamged. If it does you just need to associate the .ext with a program. Double click on the drive if a option box doesnt open up, you should see the audio files.. just right click on one and select properties. You should see the program the file is associated with. Just click change and select another program.
Dec 02, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Toshiba SD R2312 CD-RW/DVD-ROM (Combo) Burner Logo
304 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
