Compter freezing with blue screen on startup.
I need god solution of computer freezing with blue screen on startup in older to get big knowledge.
    President:
  • 1,257 Answers
Aspire 5475 freezes on startup
It is most certainly a driver, but if you cant access the safe mode also that could be a hardware issue.. Try to troubleshoot with a windows installation cd. Put it in and boot the pc. It will start the windows instalation, you choose repair computer and not install windows. The command prompt will open, try to troubleshoot from there.. Thanks!
Mar 19, 2013 | Computers & Internet
Startup very slow on my new dell 660 desktop
Sounds Like a virus, Download Spybot S&D enable it, run it and un install it after it has corrected the problem, The reason you need to get rid of it afterward is it could do damage to system files if its let to run in the system too long
Dec 11, 2012 | Dell Computers & Internet
If it is updating it will take a while to load updates. Once all the updates are installed it should Boot and shut down faster. Just let it finish the updates. do not disturb until finished.
Freezes
May be it would be registry error It sometimes when the extra and invalid entries of Windows registry make it heavy which cause situations like PC crashes, Blue screen of deaths, PC freezing etc. You can try Recoveryfix for Registry Cleaner Software. It completely scans the system registry repair errors thus making the Windows registry error free.
Check here http://www.recoveryfix.com/registry-repair-software.html for more information
Oct 16, 2012 | Toshiba Satellite L505DES5025 Notebook
Imac g4 freeze restart
This is a sign of memory issues with your Mac. Replacing the memory should not be very expensive.
Oct 10, 2012 | Apple iMac G4 Desktop
Will my hp pavilion a 420n support a 19" flat screen monitor
I have to assume you are currently using the larger size called a tube type monitor and would like to have an LCD or flat screen type monitor connected to your computer.
To connect to new LCD flat screen monitor to your computer would be exactly the same connection as what you are currently using.
The only problem you could run into is the connector itself. Some of the flat screen LCD monitors do not have the older style connector called VGA, usually blue called DB15, because it has 15 pin connector. They may have only have the newer style called a DVI type. Some do have both types.
Please be sure the LCD you want has the older style DB15 connector to connect to the rear blue VGA input of your compter.
Good Luck
Aug 30, 2011 | HP Pavilion a420n PC Desktop
My laptop is on but the screen is blue and won't go to the desktop
A Mac that shows you a blank blue screen instead of logging you in may be afflicted by a malfunctioning startup item. Most people have a number of programs that start up whenever you log into your computer, and it's likely that one of these programs is causing issues. The startup item is unable to load, and so it causes the rest of the computer to hang.
In order to get your Mac past this hanging blue screen, you need to boot into safe mode and figure out which startup item is causing problems. The Apple Support article "I see a blank blue screen when I try to start up my computer" tells you exactly how to go about this procedure. Basically, you must remove all your startup items and add them back in one-by-one, rebooting each time until you find the one that causes the hanging blue screen.
Dec 28, 2010 | Computers & Internet
The computer is on, but the screen is all blue
Dec 28, 2010 | Apple MacBook Mac Notebook
G 60 White screen and freezes
You can try to do a System Restore the laptop and bring it back to the state that it is working properly or you can also use the Recovery CD, You can do a Clean Install as well. The computer might be infected by a virus, spyware or malware that messed the compter
Thanks for using Fixya
Aug 01, 2010 | HP G60-230US Notebook
Blue Screen
When the computer first boots up, press the F8 key when the eMachines logo is replaced by the first Microsoft screen, then select Safe Mode from the list. If the computer will not boot in Safe Mode, you will need to boot from your Windows CD and select the repair installation option. If you can boot in Safe Mode, you will need to find out what is causing the system to reboot during startup. With the msconfig utility, disable all unnecessary startup programs and services, then try restarting the computer normally. If this works, you need to use the msconfig utility to add the startup programs and services back one-by-one until it fails to boot again (to locate your troublemaker). Keep repeating this until all services and programs (except the one causing the problem) are back in the lineup.
Jun 01, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
David Payne
David Payne
