Question about Car Audio & Video
I have a kenwood head unit with 3 rca outputs,front,rear and crossover is a kicker kx3 and it only has front and rear in and front,rear and sub question is how do i hook up the crossover since it only has 2 inputs?should i not use the sub out rca coming from the head unit and just run front and rear and then from crossover hook up sub from sub out???? i am also running two amps,one for sub and one for highs,thanks
  • 116 Answers
No. I would recomend running front and rear to the crossover. Use the sub out on the deck so you have total control of subwoofer output at your fingertips. Your deck should have at LEAST an 80hz crossover built in. Any further fine tuning can be done at the sub amp.
Larry T
Winona Lake,IN
Posted on Jan 28, 2009
RCA jacks on kenwood head unit do not function
Just run your amp on the front RCA and tune it on your amp they can blow which sounds like whats happend hope this helps
Mar 18, 2013 | Kenwood Car Audio & Video
Head unit connect
You will only be able to use this EQ on the front or the rear speakers. You will have to get another EQ if you think you need one. Usually, the front speakers of a car's audio system are the smallest and the rears are larger. You really do not want an EQ on the subs. If it was mine, I would hook the EQ between the head unit and the rear speakers. If you feel this does not sound right, you may need, but I doubt it very much, to get another EQ for the front speakers. Good Luck
Aug 18, 2007 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Alpine eq 3331 install
Mar 26, 2009 | Alpine ERE-G180 11-Band Car Equalizer
How to hook up my rem amp wire to this player it does not have
If by saying amp outputs you are refering to the RCA jacks on back of the head unit (Left and Right RCA jacks usually labeled FRONT, REAR, SUB, etc...) then you do have options even if your head unit doesn't provide a SUB channel.  These RCA jacks/amp outputs carry the signal (music or whatever) at a lower voltage (and is typically more like DC voltage as there is a ground reference which is 0 volts and signal rides on the positive voltage), providing a cleaner signal to the amp which does all the work.  The wires behind the amp that you connect directly to the speakers is typically amplified by the head unit itself and is a much higher voltage level and varies from negative to positive ( AC voltage.).
You could use the other channels (FRONT or REAR) if available, (a specific SUB amp output cuts all the higher frequencies out, passing just the lower subwofer frequencies inside the head unit).
if you want to strive for a more efficient use of your sub, use a low-pass/SUBwoffer filter (a crossover) in between the Head unit and amp, thus providing the amp with subwoffer signal, (or if for some odd reason you have SPEAKER level sub connections you can use a line output converter which will let you run RCA to the amp.)
Hope this helps u understand why I couldn't just say get a new stereo nor could I just say use splitters on available amp outs.
Mar 05, 2009 | Lanzar SDBT75N Car DVD Player
Install my Kenwood KAC-9102D in my 2006 Acura RSX Type S
You will probably need to use a Line Output Converter (LOC). They're available at virtually any shop that sells car audio.
Many times, the outputs of the OEM amplifier will have significant DC voltage on them. This could damage the input circuits on the kenwood amplifier.
Let me know if you have any other questions.
Aug 24, 2008 | Kenwood KAC-9102D Car Audio Amplifier
How to install kenwood kac-9102d in 2006 acura rsx
My recommendation is to get a line level converter. Go to a car audio shop or even best buy and specifically ask for a line level converter. It will have speaker wires in and RCAs out. Connect the speaker wires to the sub woofer speaker wires and then you will have the RCAs to run to your amp. I hope this helped.
-Andrew Hawkins
Aug 24, 2008 | Kenwood Car Audio & Video
I just bought a KDC MP-235 to put in a 95 camaro with bose amplified speakers. I ordered a amplifier intergration component to reduce the output of the 50 watt per channel head unit as to have better...
Yes, the Kenwood KDC MP-235 has two (2) line level outputs (RCA types red & white). However, these outputs internally passed through an electronic crossover/filter making them appropriate for subwoofer amps only.
If your unit is an MP-235CR, then the same outputs would be for the rear amp (not subs) and are full range (unfiltered).
If indeed your unit is an MP-235 and if I may make a suggestion, still connect the Kenwood to four (4) speakers. It would not be technically correct to leave the internal amps operating with no load (speakers) connected. Additionally, you would be getting 200 watts (4 X 50) more to your system (since it is already there).
If your Bose amp & speaker are subs, then no issue, however if the Bose is for a full range of speakers, then only the woofer part would be working efficiently.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 15, 2008 | Kenwood Car Audio & Video
Car amplifers,,,,kicker amp's RCA jacks!
You could do a couple things if your head unit has all three outputs, then take them and hook them into the inputs. If you have just the front and the rear outputs, hook those to the inputs front and rear. Then hook the output of the 4 channel to the input of the mono block. I hope this helped
-Andrew Hawkins
Mar 28, 2008 | Audio Players & Recorders
Car Audio & Video Logo
109 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
