Question about NetGear RangeMax NEXT WNR834B Wireless Router
My laptop will not reconize my router nor any other in the area
My laptop will not only pick up my wirless rounter it will not any in the area. I have two others in the same room and are not having any problems I am having he problem with a Gateway / Vista.. when the cable company put in a new internet cable modem to add phone service is when its started. I would get booted everytime the phone would ring. now after two weeks I can't even fine a wirless connection on my laptop.. no other problems with the other two.. no one can find the problem.. thank you
  • 3,153 Answers
Seeing as your other computers seem to work well I doubt it is your router that is at fault
I would start by checking all the wireless and network settings on the machine that is having problems.
I would turn off "wireless zero config" from the administrative tools / services first of all.
Then I would check the TCP/IP properties to ensure that "find ip address automatically" and " find dns servers automaticaly" are ticked.
As far as the problem starting since you went to VOIP it is possible but unlikely that that is the cause, and as far as getting booted when the phone rings that is for sure a cable company issue and certainly one you should follow up on as it sounds like a poor installation or faulty equipment (hope you are not a rogers or shaw customer as that would be your problem with the booting right there)
Posted on Aug 11, 2009
Linksys Wirless G Broadband rounter, trying to find my password. where do I look?
You can give a try using the HP Network diagnostic tool and it should give you your network details
Click on the link below and follow the steps
HP Network Diagnostic Tool
Regards,
Ron
Mar 18, 2011 | Computers & Internet
We bought a new router, now my new router doesn't reconize this printer? How do we fix this...I love wireless printing. This is a great printer I don't want to get a new one.
Try connecting directly to the rounter from your printer. Does it work?
If so, you know it's a wireless issue.
Get the IP address of your printer and enter the same number in your router settings.
This will avoid any conflicts.
Dec 30, 2010 | Lexmark X7170 All-In-One InkJet Printer
All of a sudden my wireless connection can't be picked up by my laptop
make surenotebook has the light indicating WIRLESS connection, also, are the hispeed modem lights on ?
Oct 22, 2010 | Blitzz Technology BWA711 Router...
How do I manage my network using a d link dir 655 wirless router, without buying network magic?
You can open a web-broswer such as Internet Explorer and enter the IP address of the router (http://192.168.0.1).
You may also connect using the NetBIOS name int the address bar (http://dlinkrouter).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default. Type in the graphical authentication code (if you cannot read it, click Regenerate).
You may click Setup Wizard to quickly configure your router.
If you want to enter your settings without running the wizard, click Manual Configuration.
In your rounter you can see who is connecting to your network and also block computers/devices from using your network.
Hope that helps.
Jan 15, 2010 | D-Link Xtreme N DIR-655 Wireless Router
On my wirless rounter i have every light on accept for my wirless light, could you please tell me what i'm during wrong
Hello mate,
you will need to connect your computer via Ethernet cable to your router and then access to the router web configuration page and check if the wireless is enabled.
If it's disabled, it's a good news. you will only need to enable it and it will start working.
if it's enabled, in this case there are two possibilities: 1. the wireless is working and it's only the light which is not working, you can verifiy that by scanning wireless available from your pc and see if your router appears in this list.
2. the wireless function is brooken: in this case, you can try to do a reset factory, but this doesn't help you will need to contact your reseller and i hope that the router is still under warranty because it will need a repair or exchange.
Best Regards,
Oct 31, 2009 | Belkin N1 Vision Wireless Router
How do I get internet on my laptop from my pc not using a cable?
what you would need to get is a wirless router. If you have high speed internet then you can plug the internet modem into the wireless router and then plug your main pc into the router via an ethernet cable and then set up your laptop to pick up the signal wirelessly. If you have dial up internet then you would still need a wireless router but it is a little more complicated. You could hook up the router to your main pc and then set up internet connection sharing so that way your laptop could pick it up wirelessly. hopefully this helps.
Apr 10, 2009 | HP Compaq Presario v3000z Notebook
I need help on trying to get my wireless router to work right . it is not working like it should on my lap top . for the wireless net . so what do i need to do .
dear sir
u have to chek internet connection and rounter settung set yr rounter to DHCP mode and configar yr internet in to router after configar yr laptop need to find yr rounter for that u need to run surch wizard it's automatioc found yr rounter then just pair it it's help u..:)
thanks
please vote
chinmay
Jan 06, 2009 | Computers & Internet
Dell Inspiron B130 problems
so the problem is about the laptop's Wirless try to reinsatll the driver of the wirless card and th ethernet card!! go to ur officila support page area!! and download it
plz rate this post!!
Aug 25, 2008 | Dell Inspiron B130 Notebook
How do i set up a wirless router for my toshiba satellite laptop?
One you plug in the router and connect it to your cable modem or dsl modem, your laptop should pick up the wireless signal. A diagram for this should have been in the box. The diagram should also show you how to log into the router to setup security. Go the router manufacture website. there you will fine complete instruction
Aug 03, 2008 | Computers & Internet
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
217 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
