Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Lens blur When looking at the object through the screen then taking the photo the picture is blured.
  • Canon Master
  • 19,396 Answers
That means that lens are either misplaced or dirty inside.
The lens assembly must be taken apart at a repair shop to fix this problem.
Posted on Jan 28, 2009
Camera
  • can you provide the model of your camera ?
  • try checking for any foreign object / dust or obstructions on your lens that might be causing the problem .
  • wipe your lens with a lens cleaning cloth to remove dirt / oil on your lens
Jul 08, 2014 | Cannon Cameras
Hi, well firstly, my pictures are really blur and un-focused when i take them from a distance away. secondly, my developed photos have black border lines on both sides of the photo or 1 on the left/right...
I have the same issue with the borders being black , i think its because the 24/24 setting ie square shot is selected and the developers print on rectangular paper ,I may be wrong. On the bluring have you changed the focus on the front or have you got it set on B as both may have this effect . hope it helps
Narbs
Apr 24, 2011 | Lomo Diana Mini 586 Film Camera
I have a nikon 55-200mm lens for the D40X digital camera. The pictures I take are blurred. I use the auto settings. the 18-55mm lens works fine and there are no problems with the picture clarity. Is the...
One of a few things might be happening
1. Photos being taken at high zoom (i.e. 200mm) are susceptible to camera shake, even though the lens is focusing properly. The solution here is use a tripod, zoom out, or steady yourself.
2. Photos being taken without flash when flash should really be used will result in motion blur (which is slightly different than camera shake). This is due to the camera using a longer shutter speed to let more light in, with the side effect being that objects will move while the shutter is open, blurring the picture. The solution here is to use a flash, or take pictures in better light.
3. The camera may be focusing on something other than what you intended.
3. If you are taking photos in good light with a steady hand, and the camera is choosing the correct subject to focus on, then yes, the lens could need readjusted, though this is not a very likely scenario.
If the lens is "hunting" for focus, that could be a sign that something is amiss.
A local camera shop can verify the accuracy of focus for your lens.
Mar 04, 2011 | Nikon D40x Digital Camera
When power on blured screen apear and blured image
1. Try cleaning the lens with a soft dry cloth. Do NOT blow on the lens first. 2. You could be experiencing camera shake - if you are in shutter mode and if your shutter speed is too slow for the light available you get a blurred image.
Dec 31, 2010 | Olympus Stylus 850SW Digital Camera
Sometimes when taking photos the photos are fine and sometimes they are really blurry. Why is this haening?
this may not be the camera but the lighting situation of the photo. or how the camera is held this also happens on film cameras.
if the subject is not well lit or the flash fails to go off or is blocked by a finger then the shutter stays open longer to get enough light to see the image. if the auto focus apature is blocked it will not focus on the subject and will come out out of focus
if the camera moves in the time that the shot is taken it will blur.
if the blufing is from left to right or up and down it means the camer moved during the shot.
if the whole picture is blured all over this looks like being out of focus and not due to movement.
check your IOS speed setting for your camera if it is set low then the camera will needs a lot of light or show shutter speed to capture an image. set it to auto or higher than 100 is best for most situation
if the camera is set to manual an not automatic the camera will only shoot at the set shutter speed and this can cause bluring.
try some test shots on a table or a tripod and take several shots in automatic mode with auto focus on take them one after the other they should all be the same but if one is blurred then there is a problem with the metering of your camera if they are all fine they it is due to camera shake when the picture was taken.
a few tips.
hold the camera to the eye with the elbows against the side of the body.
in dark lit places try to use a tripod or some other support or external light source or flash.
ensure the fingers are away from the auto focus apature the lens and the flash light.
i hope this was helpful
Dec 12, 2010 | Olympus Stylus 770 SW Digital Camera
My fuzzy photos are hard to avoid. How do I take a clear picture?
There are three main reasons photos don't come out clear.
The first is focus. If your photo has something in the near foreground and something in the distant background, you may not get both in focus. This is not as much of a problem with compact point&shoot cameras simply because their field of focus is so deep.
The second cause is subject motion. If you take a photo of a moving object, that object may blur. This is the case if moving objects blur but still objects do not.
The third and main cause is camera motion. If you suspect this, try placing the camera on a table or other stable surface, use the self-timer, and take a photo. Compare this photo with one you take holding the camera.
Sep 10, 2010 | Vivitar ViviCam 8025 Digital Camera
Actions shots are blured
The various solutions include:
try to set focus range (settings), to infinity or to an approximate distance to the object you need to take a photo of as sometimes the automatic setting does not always do a godd job at focusing , or look at the lens when it is on if its got grease use a wet camera lens cleaning kit (someone touched the glass of the lens ) a s grease makesa it hard for the camera to focus , hence blurrig or go into your options and lower the iso mode or take it off night node if any as the iso mode leads to high exposure time which means any light that changes would record as a smear hence blurring or use flash.
Nov 14, 2008 | Cameras
Photo's blur alot
Blurness doesn't happens because of the number of the pixels in the cameras.
Is the picture on the computer screen blur/the cameras screen or the lens hole?
I suggest you to set the camera on Automatic station (red camera on the wheel) in day light,try to stay still see how blur the photos are when you are not playing with the parameters. it it's still blurry it could be the pulley block next to the -eyepiece. roll it until it's not blur.
goodluck
Jun 26, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
Pinseeker is blurred
There is an adjustment ring bewteen the eye piece and the body. Make sure the white ines are lined up and it should come back into focus.
Jun 17, 2008 | Bushnell PinSeeker 1500 20-5103...
Canaon is 860 Blured image. Always right hand side of picture.
Listen you need to take the camera back where you got it and tell the person at the store because it is the camera that needs to be fixed i had the same problem except with the bottom right hand corner of my camera.
Apr 01, 2008 | Canon IXUS 860 IS Digital Camera
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
