Question about SanDisk Sansa e250 MP3 Player
Low battery I bought my Sansa Clip in July 2008 and have rarely used it. I have recently tried to recharge it but the screen still shows a batterry low indication, however long it is connected to my computer. Is there anything I can do to fix it?
  • 3 more comments
  • whumpage Jan 28, 2009
    I'm trying it. Thanks
    Thanks again, it worked fine
  • Anonymous Jan 29, 2009
    hey
  • sagarka Jan 29, 2009
    i have same problem how to solve it
  • Anonymous Feb 14, 2009
    how can i recharge my sansa 2 G e250 PLAYER
  • 684 Answers
In this case wat u can do is on the Mp3 player itself u will see a slide switch which will say Hold/Unhold or Lock/Unlock............ Just make sure it is not Locked or On Hold and then try to charge it............. Will Work Fine.......... Goo Luck
Posted on Jan 28, 2009
    President:
  • 2,976 Answers
You will get a full charge if you turn it off and plug it in to the USB port. The computer MUST be turned on the entire time it's charging. When you shut the computer off, you shut the USB power off too.
Posted on Feb 12, 2009
I bought my camera in july 2006 - recently it runs
I´ve got the same issue. If you use the batteries that were in A540 in another camera, does it still work?
Jan 11, 2010 | Canon PowerShot A540 Digital Camera
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
Help. i connect my sansa clip mp3 player to my pc it says "connected" then i leave it there for 6 hours while im in computer then its still charging and it never ends.... its supposed to make that? another...
you are spoiling the battery.you should not charge it to 6hr,well 1hr-2hr is very suffiecent.
problem with your battery.so use it and recharge it when it says low battery.
recharge it only 2hr not more than that.
Jun 19, 2009 | SanDisk Sansa Clip MP3 Player
Can't see screen or change modes on sansa clip 2gb mp3
You posted your question under "Sansa Clip," so this is a Sansa Clip manual:
http://www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
This model goes to "sleep" quickly by default - pressing any button will wake it up. The button that looks like a house (if the paint didn't get rubbed off already) allows you to go one level higher in the menu tree. Have fun with it.
-Tha Mp3 Doctor
Mar 24, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Battery Low Message - Won't recharge
did u try connecting it to your computer like i do mine
Jan 24, 2009 | SanDisk Sansa e250 MP3 Player
Nothing happens when ON switch is pressed.
Have you tried recharging the MP3 player? I too have a Sansa Clip which I play in the car so I don't often see the "battery low' message, but when I recharge it the MP3 player works again. I understand it takes longer to recharge from the computer so I bought a recharger I plug into the wall.
Jul 11, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e250 mp3 player
Yes I have How do I fix it
Dec 18, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
83 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
