Question about Philips Magnavox 51MP392H Rear Projection Television
I have a magnavox rear-projection tv without av
Only signs of life is the green lcd. dont wanna fix, and am sure the set hasnt been tampered or trouble shooted. am willing to sell or part out, email me at
I fixed my problem by posting an ad for untouched parts to a magnavox rear projection tv, never used, and unmodded for all you troubleshooters, and i plan on buyiny a new tv with the proceeds, hehee
Posted on Feb 03, 2009
My phillips magnavox big screen tv model number 55p8288 doesnt have any sound when i turn it on
Check the audio setting to make sure the internal speakers aren't turned off. Check to see if it's set to use external speakers. If it is setup to run sound through an av receiver check all connections, make sure the receiver is on the correct input setting, and speaker wires.
Jul 05, 2009 | Philips Magnavox 55P9271 55" Rear...
Purple and Green Streaks
If lcd set the issue may be with the T con board which is responsible for video and any aberrations that you see on screen.
Mar 24, 2017 | JVC AV-48WP30 48" Rear Projection...
Double vision on tv with purple and green colors
This television set, as well as most rear-projections, is prone to convergence driver problems. There are two large chips (STK392-110's) in the TV that need to be replaced, as well as some resistors that are likely damaged as well. Any competent TV repair shops should be able to repair this TV for 200-300 dollars. It is important to note that if the back of the TV is taken off without the proper prep., the Digital input (DVI) will be disabled permanently.
Hope this helps you...
Dec 30, 2008 | JVC AV-56WP74 56" Rear Projection...
Bad picture
A 10 year old Rear Projection tv is usually at the end of its life. No such thing as "fluid". Best advice, get a new TV.
Dec 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Red and green lines on picture only in the corners of the pic
YIKES, I dont know about Coolant changes but I'll post my general post about the 51MP392H/17
it has links to the SERVICE MANUALS and info to other sites that might help...
GOOD luck
General post....
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
Where I got all my parts that worked:
Suburban Electronics
Manual Library you should find all you need here:
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with.
Nov 13, 2008 | Philips Magnavox 51MP392H Rear Projection...
You need to replace your STKs Big black ICs 392-020 replace both of them also check 2 resistors 2,7 ohms they may be open.this is a common repair iob.
Nov 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox WS55859
SET will not turn back on untill you have it fixed,check out hori output ,shorted diode, or STKs need replacing.
Sep 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
TV- rear projection
If you try to adjust this you will make more work for yourself. The problem is convergence amps go bad and anything you adjust now has to be readjusted when problem is fixed. Also, convergence problems are a very common problem in all brands of projection televisions, not just magnavox, because the amps run pretty hot holding the colors in aligment. It's unfortunate you had bad luck with this set but we are also now seeing LCD, DLP and PLASMA sets that barely make it through the first year. More and more brands only carry a 90 day warranty now, so they know the life span is decreasing. To repair your set you will need soldering/desoldering equip. and test equip. or you could pay someone with experience 175.00-375.00 to solve your problem for you. That's why we're here. Lots of luck, Russmann.
Jun 16, 2008 | Philips Magnavox 51MP392H Rear Projection...
New bulb replacment for 51mp392h magnavox
you dont have bulbs you have crt's (picture tubes) red green blue. Tell me which one you need and I can post you a link, it's not hard but you do need the service manual for your tv to set it up right
Apr 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips rear projection color and pic problems
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here.
Mar 22, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 51MP392H Rear Projection Television Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
