Samsung tv Le40A558P3 does not start red front lamp blinking 6 times
ctf1800
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
mistersony
  • 320 Answers
SOURCE: Sony Grand Wega 60" indicator lamp blinks 5X green then 6 red
It is unusually to see BOTH of these flash codes together. I have never seen them at the same time. A 5 flash is a lamp driver error, which is possibly related to your lamp failure. You may have to replace the lamp driver or "ballast" to correct this problem. The 6 flash is a power supply problem and more serious, as it will likely take a technician to narrow down exactly where the fault lies. It may be a thermal fuse open OR a failure in the power supply itself. What was the original symptom that caused you to replace the lamp? Did you use an original Sony lamp as a replacement?
Posted on Nov 27, 2008
rockitman187
  • 2559 Answers
SOURCE: kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Posted on Jan 30, 2009
  • 17 Answers
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Posted on Jul 11, 2009
SOURCE: lg tv 52sz8r-tb new lamp installed, red lamp light still on
you need to reset your lamp hours timer. as far as i know this can only be done with the service remote
Posted on Jan 12, 2010
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Samsung s50hw-yb01 red lights blinks 6 times
Google the model number with "error codes" or 6 blinks or as last resort call Samsung customer service
All blink codes indicate something wrong in the set and are only general in nature--will not of course say replace this specific part.
Apr 09, 2012 | Televison & Video
I turn the tv on the green light blinks 5 times and the red light blink 6 times
this isn't a solution, I have the same issue. Mine started doing the 6 red blinks yesterday. How do I fix it? I've changed the bulb before...
Jun 18, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
SONY GRAND WEGA KDF55WF655
tv turned off black screen and red light flashes 6 times over and over again
Feb 28, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Samsung 42 inch projection
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Feb 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung SP43W6HPX\XEU Rear projection
Oct 25, 2007 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
