Question about DIGITAL PRISM 3.5" Color Pocket Lcd Tv Television Ntsc Atsc-301 Rechargeable
Can not pick up any channels after auto scan - DIGITAL PRISM 3.5" Color Pocket Lcd Tv Television Ntsc Atsc-301 Rechargeable
Auto scan not working??
Make, model, and year please.
Jan 22, 2016 | Televison & Video
When I did the air auto scan it only picked up two channels. How can I get more channels?
The auto scan picks up whatever channels are available, if it only picked 2 then that is all you have available
Dec 11, 2015 | Pegasus 7" ST07-B Portable Handheld...
Tv only picks up channel 30 when auto scaned
Tuner fault. Check and repalce it. Contact any service technician. Gopakumar Gopalan Google
Feb 28, 2014 | Sceptre Televison & Video
Run channel auto scan
The auto scan feature scans the various channel frequencies looking for a signal. Weak signals may be picked up on one scan and missed on the next. Check your antenna or add a antenna power booster and try again.
Sep 18, 2013 | Sony BRAVIA Televison & Video
No Database - won't pick up channels when doing the Auto Scan
Mine did that and I had to tighten the connection better from the wall cable into the input.
Feb 16, 2013 | Pegasus St09-b 9-inch Digital Tv Atsc...
Need to scan channels
you can do the auto search channel. just press the tv menu and then find the channel search and select auto search. so that all available local channel will tuned.
Aug 30, 2012 | Insignia NS-LTDVD19-09 LCD TV
I have a RCA LCD TV model no. RLC3708A and when hooking it up when I took it out of box, I got to
I think you are confusing the channel on the tv and the channel of the cable company that is not something that you can pick up with the scan tv, scan tv is good for picking up local channel meaning air channel that we get with a antenna only not the cable chanel
Jun 24, 2012 | RCA Televison & Video
Dynex 32 Inch Installation Problem
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
Nov 28, 2009 | Televison & Video
Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
Jun 22, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
LCD 32 inch Auto Scan issue
I have experienced exactly the same issue on two Westinghouse sets. Try turning the set off when it reaches 83%. When I turn mine off and back on, it has saved the channels -- at least the ones it had found before it got hung up.
Aug 25, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
DIGITAL PRISM 3.5" Color Pocket Lcd Tv Television Ntsc Atsc-301 Rechargeable Logo
49 people viewed this question
Top DIGITAL PRISM Televison & Video Experts
Electro Med Services...
Are you a DIGITAL PRISM Televison and Video Expert? Answer questions, earn points and help others
