Question about Dell (PS-5201-8D2) (PS52018D2) 200-Watt Power Supply
Pin out for a dell PS-5201-8D2 power supply - Dell (PS-5201-8D2) (PS52018D2) 200-Watt Power Supply
Use caution, some older Dell machines used a non standard, proprietary pin-out on the 20 pin connector ALso the 6 pin is suspect. If you connect a regular ATX PSU, you will fry the MoBo. Look here
DELL ATX motherboard Power Supply pinout
Posted on Sep 08, 2015
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: DELL POWER SUPPLY TYPE PS-5201-5D REV.F
230 Watts.
Here are specs and replacement:
230W ATX Power Supply - PS-5201-5D - HP-233SNF ...You can also replace it with a compatible 300 W psu.
Posted on May 27, 2008
JaxPlanet
  • 922 Answers
SOURCE: Dell ATX(12v) power supply
The fact that it is made by Dell is irrelivent.
ATX is a standard and so are 20 and 24 pin motheroboard connectors.
You should find what you need by searching for: power supply unit on Wikipedia and Google.
Posted on Apr 08, 2010
ginko
  • 19396 Answers
SOURCE: Power supply Dell NPS-200PB-73M
You can buy it here.
Posted on Mar 01, 2008
Gateway 507gr wont power on but looks like ps unit is good
Make sure you are plugging in your P.S. to Motherboard properly. This can happen if you are off by one pin on a 20 pin Supply on a 24 pin Motherboard. If you never opened the case and it just started happening, maybe one of your cards came out of its slot or your CPU Fan is not running.
Nov 06, 2009 | Gateway 507GR PC Desktop
How to switch on Dell PS-5201-7D
Just ground to grey wire and power is on.
Oct 12, 2009 | Dell - PS-5201-7D (PS52017D) Power Supply
DELL HIT BY LIGHTNING, WILL NOT TURN ON. HOOKED UP ANOTHER POWER SUPPLY TO IT, BUT ONLY AN EMBER LIGHT CAME ONE. BUT IT WAS A 20 PIN, AND MY DELL IS A 24 PIN.
you'll need to match the power supply, if it's 24-pin, you need to use a replacement 24-pin power supply, otherwise you will not be able to power up the system. I recommend checking dell's site for a replacement, or tigerdirect for a compatible aftermarket power supply. They're relatively inexpensive.
Sep 22, 2009 | Dell Dimension C521 PC Desktop
HP-233Snf
Anytime you see a Green wire in a computer, (Personal Computer), power supply's ->power cable, it is for the Soft Power On function.
This way there isn't a cable, (Cord), going from the Power On switch to the power supply.
These are ATX style of power supply's.
The Black insulated wires are Ground wires. ALL of them.
There was a older power supply made, and this was the AT style.
To provide a solution, I'm going to give you some information on the power cables, for Both of these styles of power supply's, then some advice.
1.This is info, and photos of the older AT power supply's power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpc
2.This is the newer ATX style power cable, and more specifically the 20-pin version,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Scroll down the page to view the 24-pin power cable, and then scroll down some more, to view the 20+4-pin power cable.
ALL ATX design power supply's use Pin 16 for PS ON, (Soft Power On), which is a Green wire, and ANY Black wire. ALL Black wires are a ground. Pin 15 has a Black wire, and is normally used to put a jumper in, from it to Pin 15. This turns the power supply on. There will be a small spark, and the chance of getting shocked.
What you are doing essentially, is using a personal computer power supply as a laboratory power source, therefore I cannot advise you further, as it is a Safety Hazard.
Jul 31, 2009 | Dell POWER SUPPLY PS-5201-5D (PS52015D)...
Power edge 1800 bought october 2006. It does have a DELL 650 Watt non-redundant power supply, type nr. PS-5651-1. Can I replace it with a standard ATX power supply, or is the connector not standard wired...
Dell uses proprietary psu's. You will need to contact them for replacement psu or find a supplier that makes psu's that can be used as a Dell replacement. Hope this helps.
Jul 07, 2009 | Dell PowerEdge 1800 Server
Compaq power supply HP212 (old)
If connector have two big brown wires (pins 1 and 11) and a small brown wire (pin 2). then short circuit the small brown wire with a big brown wire (pins 1 and 2).
Also short circuit the small black wire (pin 16) with a big black wire (pin 17).
Ps. The Power Supply needs a minimal load ex: 1A.
Dec 04, 2007 | Dell HP-150SS (HP150SS) 150-Watt Power...
Dell 5100 Dimension - No Power
there are fuses inside psu`s some are solderd and some pop out it i would suggest that u throw the psu away and buy new chances are that it will only cause continues and may even result in
complete mobo failure problems heres a link to a cheap psu   http://www.microdirect.co.uk/(3649)400W-P4AMD-quiet-PSU-with-PFC-20-pin-24-pin.aspx or a more upmarket more powerfull http://www.microdirect.co.uk/(11879)ThermalTake-TR2-500W-Black-Silent-ATX-12V.aspx the choice is yours.
Nov 18, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
756 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
