Question about Genuine Konica Minolta Genuine Bizhub 222/282 Black Toner Tn211
How can I solve the problem in Konica Minolta Bizhub 282 error code C4101
How can I solve the problem code error C4101
  • Genuine Koni... Master
  • 6,161 Answers
You have Print Head Failure, the Print Head houses the LASER along with the LASER is a motor, your code deals with the motor, Motor can not be replaced, entire unit is, try this site they mite have it or will have to get a Konica Minolta Dealer, Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Nov 20, 2015
2 Suggested Answers
  • 61 Answers
SOURCE: Abort code
contact service use go to www.konicaminolta.com
Posted on Oct 07, 2012
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
I have a konica minolta 280 an there is a code c4101 . how to clear this code
The print head is bad.The print head is what houses the LASER. Its a large assemble under the image units. Open close the front door and or the right door.to reset the code. if it come back replace the print head, but also check all connectors to current print head and control board the controls it.
Jan 08, 2016 | Konica Minolta Bizhub C280 Color Copier
Bizhub 282 E73000 error code
CAUSE: With Gmail, the MFP must support SMTP over SSL/TLS. The bizhub 200/250/350 and bizhub 222/282/362 series do not support this functionality.
SOLUTION: An E-mail server that does not require support for SMTP over SSL/TLS would have to be used.
Hope this helps you
Dec 11, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
THE COPIER DISPLAYS ERROR C4101
C -4101 Polygon motor error.Change the polygon motor,if you can not reset the malfunction code.
Mar 02, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
I have a code error c4101 in minolta 350 bizhub
Does the machine come to ready state? and if it does, does the code blow as soon as an original in placed in the df or the start button is pressed?
Make sure you have 2 ribbon cables and one connector running through back of machine from PH unit. Also make sure you have the correct ph unit installed.
Here this is straight from Konica ...
C4101 code at power up.
Description:
Solution:
PROBABLE CAUSES:
1. Failed PWB-A (Mechanical CB).
Replace the PWB-A board (p/n 4040 0101 03).
2. No 24V DC at PJ17A, pin 5.
Replace the 3.15A fuse located on the power supply.
3. Polygon motor in the Print Head Assembly fails to turn.
Begin by checking the connections to the Print Head Assembly. Unplug and reseat all connections. If issue continues, replace the Print Head Assembly (p/n 4040-0751-00).
C-4101 (C4101) at power up.
Description:
C-4101 at power up.
Solution:
CAUSE: Failed BCRS board.
SOLUTION: Replace the BCRS (p/n 4551 2033 01 for bizhub 350 and p/n 4551 2034 01 for bizhub 200/250).
G.L.
Apr 24, 2011 | Computers & Internet
Error code c4101
Error cod C4101
Machine Konica Minolta c6500
Nov 25, 2009 | Minolta bizhub 200 All-In-One Printer
Genuine Konica Minolta Genuine Bizhub 222/282 Black Toner Tn211 Logo
111 people viewed this question
Top Genuine Konica Minolta Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Genuine Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
