Question about Hurricane New Gaui 200 Radio Control Helicopter - (Belt Drive) Carbon Fibe
Hurricane 550 battery problem
Hi All,
I've got the battery pack (20C 11.1V 2100mAh) that is working perfect for hurricane 550 but only last for few minutes of flying time.
I change the battery pack for (3C 11.1V 3300mAh) in order to extend the flying time but it doesn't working at all.
The receiver and ESC are working but the blade doesn't rotate at all.
I would like to know why
it's because the 3300mAh is too big for ESC or some other problem?
can anyone help me out here
Many thanks
Joe
Hi All,
Thanks for your reply.
Finally, I've solved the problem. The battery that I've got previously produced 42 volts each and I connected two in series configuration. So the voltage add up together become 84 V for ESC.
That's why I can only fly for twice and it didn't last for long. The batteries were bubble up and really hot, basically, I busty it. Besides, the ESC is cooked.
So, I bought two brand new battery packs ( 3C 11.1V 3300mAh) and an ESC. The ESC has built in switching mode.One of the socket from ESC is connected to the switch with black and red wires were wrong way around. After I've swap it everything works. By using this way, there is no needed the extra 9V batter pack for receiver.
Your Sincerely,
Joe
Posted on Jan 29, 2009
1988 Honda CBR 750 Hurricane firing order
Hi, David for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1988 Hurricane Firing Order CBR Forum Enthusiast forums for Honda CBR...
1988 Honda CBR 750 Hurricane firing order Google Search
http://www.home-business-host.com/images/cbr/CBR1000F%20SC21%20(1987-1996).pdf
Honda CB750f2 Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB750F2 Owner Manual
Nov 27, 2017 | 1988 Honda CBR 750 Hurricane
Keeway Hurricane engine number location
Hi, Sc4t for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
KEEWAY HURRICANE User Manual Page 7
http://www.49ccscoot.com/manuals/Keeway_50cc_2T_Service_Manual.pdf
Hurricane 50 Keeway Scooter Parts Racing Planet USA
http://get2itparts.com/_zz_keeway/Hurricane_Body_06-08.pdf
Jun 29, 2017 | Keeway Motorcycles
1988 Honda CBR 750 Hurricane no spark on 2 and 3 cylinder
Hi, Anonymous and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Tilt sensor needs a reset.
11. Security alarm failing to disarm needs reset
Testing Honda Coils and CDI boxes
88 Hurricane 600 No spark CBR Forum Enthusiast forums for Honda CBR Owners
414results for hurricane manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Oct 20, 2013 | 1988 Honda CBR 750 Hurricane
I HAVE A M1 HURRICANE HELICOPTER AND THE LIGHTS COME ON BUT IT WILL NOT FLY. CHANGED THE BATTERIES IN THE REMOTE BUT STILL DONT FLY.
Using a multi-meter, check the voltage of your helicopter's batteries to verify that you have a charged battery pack.
If so, verify that your battery is connected to your helicopters circuit. There should be a white plastic connector that plugs the battery pack into the helicopters on board systems.
If everything is connected correctly and you are reading a very slight voltage from the helicopter's battery, then most likely you are not getting a good charge coming from your power charger. If this is the case, go here:
http://www.fixya.com/support/t23269551-gyro_m1_turn_remote_but_get_spin_blade#answer
Hope this helps.
May 29, 2013 | Skytech M1 hurricane large 1:25 scale gyro...
How do you get the seat off to remove the battery on the Hurricane?
you need to turn the seat first with the right lever so it is at a 90 degree angle then wiggle it while pulling up...sometimes takes a bit of wiggling but it will come off
Nov 05, 2012 | Pride Mobility Products Hurricane PMV...
Pride hurricane batteries (2008,model)
Hi...
You'll get a little more time out of the 55ah ( like 10%)
Mar 31, 2010 | Pride Hurricane 4 Wheel Personal Mobility...
Hurricane New Gaui  200 Radio Control Helicopter - (Belt Drive) Carbon Fibe Logo
121 people viewed this question
Top Hurricane Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Hurricane Toy Expert? Answer questions, earn points and help others
