Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Frigidaire Dish Washer Model # FD81050REB2 - Top Rack not cleaning.
The top rack is not cleaning the dishes. The top cleaning arm spins freely, does not have anything blocking the jets, and seems to be moving (slowly) during the cycle. The bottom Arm Spins freely and cleans all the bottom dishes, none of the hole are blocked and water sprays out freely. I did notice on the bottom arm one of the end holes is chipped and not directing water correctly. Is that possibly causing the problem?
4 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: Spray arms not turning
it seem the problem is in microswitch thats control the mechanism of the motor to move the arm,,you better checked it out that switch or change that..the failed of synchronization of movement of the arm is cause also in the system,just try this also go to menu setting and default the factory setting ,its to reset try this option..
Posted on Jun 20, 2008
milten1
  • 1304 Answers
SOURCE: top rack does not clean, white residue all over
the white residue is actuially soap
at the risk of a bad rateing
try refilling your jet dry
or dont use those mixed soaps
also check to ensure there is nothing clogging the holes on the spray arm
hope this helps
Posted on Oct 24, 2009
heatman101
  • 43501 Answers
SOURCE: glasses and dishes on top
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 15, 2011
Top dish rack dishes don't get clean model 8575637
Most dishwashers have a rotating spray bar underneath the upper rack. Over time bits of food can clog up the holes and then dishes won't get clean in the upper rack. Check to make sure all the holes in the spray bar are clear and that it is rotating freely.
Mar 22, 2017 | Dishwashers
GE Dish Washer GSD 2800 DO3 runs a partial cycle...(even empty) and then beep and gives a message on control panel "washer arm blocked". Even ran without dish rack in washer still got the...
the rotating arm has a magnet in it to let the controls know if it is turning. Yours is not turning so
  • check the jets for blockages... you might have to remove the arm to clean them properly
  • make sure there in nothing stopping the arm from turning...spin the arm manually to see if it rotates freely.
  • knives etc sticking upward can stop the arms from rotating on the top rack
  • if you run without the rack the arm will obviously be not telling the electronic it is not blocked because it is not there. the rack must be in the machine with the magnet and the magnet passing correct messages.
  • If there is really no blockage then there is a elect fault that need to be sorted professionally.
  • PS have you taken the arm off anf squirted a hose up the inlet to see if water comes out all of the jets????
Mar 01, 2011 | Dishwashers
Dish washer not cleaning dishes in top rack
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Jan 13, 2011 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Top rack of dish washer does not have enough water
Trouble shooting here... but the same pumb that circulates water... vents it.... So, if the vent valve is clogged with food debris, then you would not retain enough water to wash all the upper rack dishes...
I recommend inspecting the exhaust tube port of the pump (a selenoid is the operating device for that valve). Be sure that it is able to operate freely (close all the way. Otherwise, it is just the pump intake!! only choices...you have already eliminated the rest (GOOD JOB)
Dec 31, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishes bottom rack are marginally clean. upper rack is never clean anymore. The dish washer cycles through NORMAL and Dries dishes OK. Motor is running, and rinsing can be heard as well as washing cycles....
Just fixed my Frigidaire. The outboard o-ring on the main pump became distorted and stretched. Check your local hardware store as Frigidaire wants $17.50 + shipping. Good luck
Dec 25, 2009 | Dishwashers
Instruction for the top dish rack were missing from my order. The rack is for Whirlpool quiet wash plus dish washer. Do you have the instructions?
The top rack is generally for things like glassware, bowls, cups, saucers, and plastics items. Smaller and more fragile pieces go on the top, bigger items on the lower rack. This is the general rule for all dishwashers.
Oct 13, 2009 | Dishwashers
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Mar 18, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Top rack remains dirty
spin the top rotary arm to make sure it spins freely also take it off to see if its blocked (run it under tap) check all other filters too and when you load dishes make sure they do not obstuct top rotary arm if none of this works then it's time for an engineer im affraid good luck
Jan 26, 2008 | KitchenAid 24 in. KUDK02CR Built-in...
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
54 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
