Question about Design House 204784 Drive In Ball Catch for Dummy Knob Satin Nickel, P
How to remove door ball catch mechanism - Design House 204784 Drive In Ball Catch for Dummy Knob Satin Nickel, P
How do I fix a sticking door catch?
Buy door latch lub for auto parts store.
May 26, 2014 | 2005 Renault Grand Scenic
Microwave door will not close properly
Door catches.
Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Feb 03, 2011 | Microwave Ovens
Door has been an issue when closing light stays on and you really have to slam the door for the light to go off
Door catches.
Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. The door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Jan 24, 2011 | Whirlpool GH4155XPS Microwave Oven
It's a 2000 chevy venture the rear door lock mechnism will not open or close. at the present moment the truck door is open and tied down with string because the lock mechanism will not engage. How can...
There should be a small removable panel inside of where the latch is located. This is usually a pop off panel. Once removed you can inspect the mechanism for movement problems. Another quick fix if only the catch alignment is in the wrong place...Use the inside lock mechanism and pull into the unlock position...this re-aligns the catch to the open position, (lubricate with PB Blaster...most parts stores including Walmart:) This re-alignment of the catch may solve your problem. Your Venture is a popular model...if you have the wear-withal...you can visit your local salvage yard for a working latch...:) Hope this helps.
Jan 21, 2011 | 2000 Chevrolet Venture
We have a Panasonic Genius Prestige 1200 W microwave. The door won't open. Tried unplugging and plugging in; that worked once, but now doesn't help.
Sounds like the door catch is stuck. Perhaps this will help;
Door catches.
One of the latches has broken off and is not lifting the dother latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Jan 01, 2011 | Panasonic NN-SD797S Microwave Oven
Hasbro nerf cosmic catch keep away
1. Choose a color hand band and place it on your hand as shown. All
players do the same. Place any unused bands out of play.
2. Press the ball button to power it up. You will hear some music and
the ball will announce: COSMIC CATCH!
3. The ball will then announce: PLAYERS SIGN IN. PASS THE BALL TO
EACH PLAYER. Hold the ball (with color band on) so that it knows
Loosen the screws on the battery
compartment door.
Then remove the door. Insert 4
AAA-size batteries (I recommend
alkaline), making sure to align the
+ and – symbols with the markings
in the plastic. Replace the door and
tighten the screws.
you are playing. The ball will announce your color. Then pass the
ball to the next player until all players are signed in.
4. After all players have signed in (held the ball), pass the ball back
to the first player that signed in. The ball will then know how
many players are in the game and announce the players’ colors.
Note: If a player takes more than 2 seconds to pass the ball, it
will announce: KEEP GOING. If the ball is passed to a player who
has already signed in but was not the first to do so, the ball will
5. The ball will then announce: SELECT GAME. Press the ball button
to select the game you want as shown below.
May 28, 2009 | Hasbro Fur Real Friends Smores Pony
1999 clk 320 driver door makes loud clicking noise
tony i'm assuming you on about the little bar/plate about an inch wide which seems to rattle about when you open the door??? This is i suppose the check strap and it is designed to hold the door open while not letting the door go too far and become hingebound, bending the hinge and possible damaging the door panel. If it is making a clicking noise it may need a bit of lubrication as it will go over some kind of ball or ridghe to slow it down. If it is completely loose it may be catching something inside the door, possibly the window frame guide or the internal skin of the door. check the mounting bolts on the door post and in the resess on the door and tighten them up and lubricate the rod. You may need to remove internal door skin, window switches etc to get to it. what ever you do do not remove it altogether, as one day the wind may catch it and take the door right around 180 degree causing serious damage, they are not designed to stop the door completely and can stretch if the wind does catch it so check it for damage to as it could effect the door hinges later on
Lee
Mar 16, 2009 | 1999 Mercedes-Benz CLK
Inside lights
Remove "Door Ajar" switch. Clean the switch and use a graphite type lubricant (I recommend "Dry-Slide") to lubricate the actuator on the switch. Reassemble the switch.
The switches are located inside the door panels, attached to the catch mechanism.
1) Remove interior door panel.
2) Using a T-27 Torx driver, remove the 3 bolts holding the catch in the door.
2a) The door ajar switch is the only part on the mechanism with the 2-wire harness.
2b) The switch is located at the rear catch for the sliding door.
3) Using a small flat screwdriver, gently lift the black tab on the catch mechanism and rotate the switch to remove it from the catch assembly.
4) Using a rag, clean the small round actuator and apply a small amount of graphite lubricant to the actuator and work the switch so it moves freely.
5) Reassemble the catch and the door.
Jul 20, 2008 | 2003 Ford Windstar
Door not closing, mechanism not ingaging
Hi. Have you checked the "child safety" catch the prevents the door being opened from the inside? That might be in the wrong position and causing a problem. I had a problem on my 93 Golf and I got it working again by exercising the catch mechanism with a screwdriver - pushing the locking mechanism- the greasy bit on the edge of the door - up and down numerous times and lubricating it again.
Hope this helps. If this "fixes ya", I'd appreciate a rating for my reply, If not, please delay the rating and add a comment with any extra info you have and I will try to think of something else.
Cheers, D.
Jul 11, 2008 | 1996 Volkswagen Jetta
Design House 204784 Drive In Ball Catch for Dummy Knob Satin Nickel, P Logo
77 people viewed this question
Top Design House Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Design House Hardware and Accessory Expert? Answer questions, earn points and help others
